Short Shifter - The BMW parts bin way. - Page 4 - BMW M5 Forum and M6 Forums
Old 12th August 2006, 16:38   #31
Simonal
Simonal's Avatar
Garage: Alpina B10 V8S Touring
Not having tried a Z3 "shirt shift kit" I cannot comment on the difference between the two.
All I can say is that the UUC item despite being very difficult to get hold of for all outside the US is a very good piece of kit.
I would agree that maybe over time the shift quality of the Z3 item may deteriorate but only time will tell.
Simonal is offline   Reply With Quote
Old 12th August 2006, 20:06   #32
Cyrus
Garage: BMW E34 M5 3.8 Avus Blue
So far Ive had the shifter in my 3.6 for about 10k miles and about 5k miles in the 3.8.
It still feels exactly like the day I put it in - tiny bit notchy but precise and very positive to use.
Changing it is very very easy even for a simple minded home mechanic like myself and no way would I pay stupid amounts of money to a company like UUC.
Sal
Avus Blue 6 speed 3.8L E34 ///M5 Sedan
Cyrus is offline   Reply With Quote
Old 12th August 2006, 20:17   #33
Geach
Geach's Avatar
Garage: 1990 e34 M5 Sebring grey
Sal
Ditto! Very worthwhile mod,wouldnt be without mine,too much time is wasted changing gear!
Dan.
'90 M5- Sebring Grey
Geach is offline   Reply With Quote
Old 15th August 2006, 09:19   #34
Binary Star
Binary Star's Avatar
Garage: Maurituis Bleu Metallic
Originally Posted by nixter
any update on the part numbers for all associated bits?
cheers,
n
(i know this is old)
x2
Binary Star is offline   Reply With Quote
Old 5th September 2006, 16:44   #35
e34M52b
e34M52b's Avatar
Garage: TiAg Silver E46 ///M3 - Sold, and forgotten
Originally Posted by farrell
Gear clash is where you dont fully engage the gears when the clutch is depressed. If the pivot ratio of the throw is not quite right, then you get a clash of gear sets as you select from one ratio to another.
It feels similar to a badly baulked gear change but the gear does engage.
Hard to explain but easy to feel.
Farrell,
I recently had a Autosolutions.net short shift kit installed. It's very high quality manufacture and the short throws are fantastic... But, it's rediculously notchy and takes considerable effort to.. say, pull back from first to engage second. Side to side isn't really an issue though.
I'm wondering if I am experiencing "gear clash" and don't even know it. I don't hear anything that sounds like when you release the clutch before the gears are engaged (bad shift)... but it seems like something isn't right.
Can you explain to me what it feels like.. What causes it?? You said something about the pivot ratio. Unfortunately, I did not install it, so I did not compare directly to the one that came out, but it bolted up with no fitment issues.
Either that, or my shifter is just VERY NOTCHY.
e34M52b is offline   Reply With Quote
Old 10th September 2006, 02:32   #36
Calgary3.6
Garage: 2007 Infiniti G35x
You need a weighted knob. That makes all the difference.
A Freudian slip is where you say one thing and you mean your mother.
Calgary3.6 is offline   Reply With Quote
Old 10th September 2006, 15:39   #37
WMWNWMN
WMWNWMN's Avatar
Garage: 1988 M5
suposedly a heavy knob can accelerate the wear on the plastic and rubber bushings. a weighted selector rod will remove the notchyness as well. you can either spend $60 or 80 bucks on a nice heavy billet piece, or wrap your factory item in electric solder, then ductape the whole unit to keep the solder from unraveling
WMWNWMN is offline   Reply With Quote
Old 10th September 2006, 18:17   #38
Calgary3.6
Not sure I agree about adding weight to the selector rod giving the same result. I have the UUC EVO SSK and DSSR. Yes, big $$ but...
When first installed with the OE (light/lighted) knob the shifting was horribly "notchy" and fetching second for downshifts was a bear even with the EVO arm set to the longest length (greatest MA). This with the DSSR that probably weighs 3-4x the OE selector rod.
Adding the RK2 made all the difference for me. After installation, I re-set the EVO arm to its shortest setting and could stand to go shorter still.
Here's a pic with the 2 setups side by side (wrong DSSR - my supplier screwed up - photo was to show the supplier the problem):
Old 11th September 2006, 08:50   #39
nixter
nixter's Avatar
Garage: 2003 M5 Silver/Black
What's an "RK2"?
n
1993 M5 Silver/Black (sold)
1980 911SC Widebody, Black/Black
nixter is offline   Reply With Quote
Old 11th September 2006, 20:30   #40
Calgary3.6
What's an "RK2"?
n
RK2 is the second generation "Rob Knob" from UUC. About 2 pounds of machined stainless steel makes a shift knob for C$145 - 2" diameter. The RK Magnum is heavier and another 3/16" dia.
BMW M Manager Bruhnke at Stockholm Open, Sweden and answer to your questions Gustav E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 51 25th March 2005 17:14
BMW M Manager Bruhnke at Stockholm Open, Sweden and answer to your questions Gustav Most Memorable Threads' 43 1st November 2004 19:16
BMW Alpina now launched in Kuwait, Quatar, Bahrain, Saudi Arabia and Oman! Gustav ALPINABoard.com | BMW Alpina Discussion 0 13th September 2004 23:31
Its Here! Real & OFFICIAL PICS of the new 5 Series car.............. FAST 5 E60 M5 and E61 M5 Touring Discussion 20 2nd April 2003 17:31
