Nurmburgring suspension and brakes - BMW M5 Forum and M6 Forums
Old 23rd April 2001, 23:05   #1
Nick P
I have a 1994 M5. It has a 5 speed manual transmission and I'm told it has the NBRing suspension and brakes, however I get the impression that only the 6 speed vehicles had this fitted as standard. The local BMW garage is currently checking. Their impression was that the NBRing suspension and brakes were colour coded yellow in later editions?? Can anybody help or suggest how I might establish what the car has or has not?
Thanks in advance for any help
Nick P is offline   Reply With Quote
Old 24th April 2001, 16:53   #2
RYAN
RYAN's Avatar
Garage: 1993 BMW M5 3.8L Avus Blue
To see if you have the Neurbring Suspension package, a simple test is to look at the dash and there should be a switch right next to the fog light switch. It is an illuminated switch, with two settings. If you have the switch (Which manually adjusts the suspension damping.)You have the Neurbring package. This was an option on all 3.8L M5's and was fitted as standart equipment on 1995 Model M5's
However, I believe that there is alot of confusion over the apparent upgraded brakes. The Suspension package does not include any brake upgrade. The only time the brakes changed was for the 1995 model year when the floating disc'c were put into production. They were not painted yellow from factory, just standard aluminum color os steel, what ever they are made of.
Hope this answers all you questions!!!!
RYAN is offline   Reply With Quote
Old 24th April 2001, 17:01   #3
RYAN
RYAN's Avatar
Let me adjust my spelling, as I know someone will correct it later!
Neurburgring
Sorry for the incorrect spelling.
Old 24th April 2001, 21:24   #4
1680
Post
With the 95 models, when the Nurburgring (sp?) suspension was fitted as standard, do you still have a switch to decide whether to use it or use the standard suspension? Also, what differences does it make to the car's suspension & handling?
1680 is offline   Reply With Quote
Old 25th April 2001, 03:58   #5
RYAN
RYAN's Avatar
Post
The Neurburgring suspension is a manual switch of the EDC (Electronic Damping Control) The system will automatically adjust the damper settings if needed, as to minimise body roll and dive and squat. It's a really cool system, but along with the manual switch,(Which will be overridden if you suddenly swerve or something) you have a 1mm thicker rear anti roll bar, and a 9 inch wide rear wheel on 255 wide tires, w/o you have an 8 inch wheel in back with I believe 235, and 245 in 1995. I think thats about it!
Old 25th April 2001, 19:50   #6
Nick P
Post
Ryan, Thanks very much for your help. The car does indeed have the rocker switch which illuminates when switched into "sport" mode. Glad that's been cleared up as both the local BMW dealer and another supposed M5 expert were struggling to figure out whether the car had the NBR package. Interesting comments about the brakes. I had previously been under the impression that the NBR package featured uprated suspension and brakes! Thanks again for your help
Regards
Nick
Old 25th April 2001, 21:24   #7
RYAN
RYAN's Avatar
Post
Nick,
Glad to help! I think there are allot of people that think the Neurburgring suspension included bigger brakes. This is not true, all M5's all had the same killer brakes. Although they were improved and made larger with the 1995 model year.
Old 27th April 2001, 21:12   #8
Nick P
Post
Are these the "rotor" disk brakes I've seen people discussing in this BB? If so do you know if it's worth updating the brakes in my 1994 M5? Indeed is this even possible??
Nick,
Yet another peevish observation about the board dwasifar E39 M5 and E52 Z8 Discussion 51 22nd December 2003 23:35
Pics of the KW suspension set VERY low !! Apples E39 M5 and E52 Z8 Discussion 24 13th September 2002 01:49
Lets talk suspension...... Tim W E39 M5 and E52 Z8 Discussion 17 22nd July 2002 14:30
Next project! - New brakes but have some questions atomic80 E39 M5 and E52 Z8 Discussion 9 16th April 2002 22:29
'98 540/6 with M5 suspension, brakes, shifter, and M5 grill basil Cars For Sale or Wanted 0 10th December 2000 06:11
