3.91 Vs. 4.1 Differential - BMW M5 Forum and M6 Forums
Old 25th October 2000, 04:09   #1
tsupler
Not to sound to ignorant, but I've seen several folks looking for a 4.1 diff for their M5's. Mine as I assume most came stock with a 3.91, if memory serves me right some later ones ,after 91, may have come w/3.71. Well anyway could someone explain to me what performance or other gain you get going from 3.91 to 4.1. Is it faster acceleration at expense of top speed or the opposite? Just wondering.
Tim Supler
tsupler is offline   Reply With Quote
Old 25th October 2000, 06:57   #2
KLittle
KLittle's Avatar
Garage: Two E34 M5's, Mauritius Blue and Alpine White
Post
Tim:
I had the same question after seeing that some were looking for the 4:10 ratio. I have both the 3:91 and 3:73 (or is it 3:71, not sure) represented in my cars. Personally I feel that the 3:91 is too low and prefer the higher ratio. I do see myself shifting too quickly with the 3:91. It is also easier to bump the rev-limiter with the lower ratio.
I did not buy these cars for their 0-60 performance, nor would I assume that many others have. I personally would not want to sacrifice the top end speed for the gain off the line.
Ken Little
'91 M5 Mauritius Blue
'91 M5 Alpine White
KLittle is offline   Reply With Quote
Old 3rd November 2000, 20:19   #3
Ken Semak
It's faster acceleration at the expense of top speed. Also, lower gas mileage and more wear on the engine (turning higher RPM's for a given speed)
Ken Semak is offline   Reply With Quote
Old 22nd November 2000, 23:24   #4
Hattar
I have a european model 1989. I don't know the ratio in this car but it's definitively too low. Guess it is 4.1, maybe somebody can tell me? The car has a "Sport" gear box. I never use the 1'st gear (it also starts in the 3'rd). At 100 km/h the engine speed is ~3 200 rpm in 5'th gear and with the rev limiter at ~7 300 rpm the car can't go faster than 217 km/h(according to the computer, 230 km/h according to the needle). This car should do 250 km/h! Fuel consumption is high, rev limiter is very active and I don't believe that the acceleration is any faster with this kind of differential. You have to start in 2'nd gear and shift gears VERY often. Maybe this differential could work better on a race track? A change with somebodys 3.91 would be nice ...
Hattar is offline   Reply With Quote
Old 23rd November 2000, 11:45   #5
raymondw
raymondw's Avatar
Garage: 1990 BMW E34 ///M5 (181), 1985 BMW E28 ///M5 (203), 1988 BMW E32 735i (198), 2003 BMW E39 530i touring (354)
Post
Hmmm,
Ommen you say. Be carefull then with the cops there. They are very keen on speeders.
Especially the road from Ommen to Raalte.
With best regards,
Raymond
raymondw is offline   Reply With Quote
Old 18th December 2000, 06:06   #6
bmwvsferrari
Post
[/b][/quote]
How is this going on?
bmwvsferrari is offline   Reply With Quote
Old 2nd January 2001, 02:05   #7
Hattar
Post
Nothing is really going at the moment but my proposal to change with somebody was (quite) serious.
Old 3rd January 2001, 05:12   #8
CarlT
CarlT's Avatar
Garage: 850CSi
Post
Hi Hattar
You should "post" your diff for sale on the www.bimmer.org forum. Changing the diff to a higher ratio seems to be a popular option for many Americans as they often favor acceleration over speed. ( No offense anyone, just facts ) Find out your exact ratio, there is a indication/number on the diff itself. 850 owners might also be interested as its a direct fit.
Regards
Carl
CarlT is offline   Reply With Quote
Old 6th January 2001, 14:53   #9
bmwvsferrari
Post
I just want to swap mine with 3.91 with something like 4.1??
Mine has milage of 54k miles.
Old 14th January 2001, 02:16   #10
Hattar
I'll keep you in mind if I finally decide to change for something like 3.91. Is it urgent for you? Your address is Honkong...
Mine has milage of 106k miles.
Tech: ETK/TIS question: differential fluid spec? Teutonaddict E39 M5 and E52 Z8 Discussion 3 26th May 2003 19:23
Appeal of a 4.10 differential samson E34 M5 Discussion 12 19th September 2002 19:09
M5 limited slip differential transplant into 540i/6 DZeckhausen E39 M5 and E52 Z8 Discussion 8 14th May 2002 13:49
The down side of the 3.46 differential Quad_exhaust E39 M5 and E52 Z8 Discussion 16 30th July 2001 03:54
My baby's back! New differential! SteveP E39 M5 and E52 Z8 Discussion 2 30th September 2000 06:14
