M5 running on gas - BMW M5 Forum and M6 Forums
Old 12th December 2000, 14:17   #1
Brian
M5 running on gas
Hi Folks,
Having driven a 1990 3.6 M5 for about 1 year, I then bought a 3.8 M5 year 1992 in 1994, which has been running fine since I bought it. Not to talk of the very expensive shocks, which I preferred to replace with a full kit from Schnitzer, which works great.
I will be commuting lot more kilometers next year and have been told of two owners of 91 M5's who had gas installations (LPG or GPL) and were happy with it. According to the dealer, they are supposed to encounter no problems when using the engine below 6000 RPM's. I would welcome any information on the topic! Depending on feed-back, I might consideer buying another car for commuting and keep my M5 for week-ends.
Thanks and have fun!!
Brian is offline   Reply With Quote
Old 13th December 2000, 21:31   #2
NRL BITURBO
Garage: Alpina B10 Bi-Turbo Alpina Blau Metallic
Post
Brian,
I am also considering this route with my Alpina B10 Biturbo. I am interested to note that you were advised that no problems would occur up to 6000 rpm. What happens above this limit? What is the typical cost of a conversion in Belgium as a matter of interest?
Neil
NRL BITURBO is offline   Reply With Quote
Old 14th December 2000, 00:04   #3
Brian
Post
Hi,
What seems to happen is that the system is not able to deliver enough gas and that the engine will misfire causing backfiring, which I believe could lead to damages to the air intake parts. According to the feed-back I have received, this has not happenened but the owner had to stop and fit back some of the inlet accessories!
I have been quoted a price of 75.000 bf + VAT, which equals to +- 1.150 £ + VAT
Cheers,
Brian
P.S.: I would welcome any comments from M3 owners having gone the GPL way as the engines are pretty similar in design.
Originally posted by NRL BITURBO:
Brian,
Neil
Old 14th December 2000, 04:45   #4
Gene Cockrell
Post
High RPM/heavy load leaning (not enough fuel) is a great way to burn exhaust valves in a big hurry...It sounds from here as if this LPG conversion is not fully thought out...
Gene Cockrell is offline   Reply With Quote
Old 14th December 2000, 11:56   #5
raymondw
raymondw's Avatar
Garage: 1990 BMW E34 ///M5 (181), 1985 BMW E28 ///M5 (203), 1988 BMW E32 735i (198), 2003 BMW E39 530i touring (354)
Post
Hello Brian,
Buy another car for the commuting work. With LPG, the M5 loses about 20%-30% power and that is a lot. Moreover, I have never seen a normal LPG fueled multivalve engine live longer than 200000km without problems to the cylinderhead and gaskets.
The problem is that with LPG, the temperatures in the cylinder head can rise to very high values and this causes high thermal stresses on the gaskets and the exhaust valves. Moreover an LPG conversion will make your M5 run lean and when at full throttle tho temperatures of the pistons and valves will rise dramatically. There are a lot of disadvantages of running lean, but the most important is that the temperatures in the cylinder head increase.
At full throttle, the DME of your M5 enriches the fuel/air mixture for a proper cooling of the the engine (exhaust valves, pistons). When running on LPG, that will not be the case anymore.
When your dealer says you shouldn't exceed 6000RPM with LPG, then he forgot to say also, don't give full throttle with LPG.
With best regards,
Raymond Woertman
1990 E34 ///M5
(Netherlands)
raymondw is offline   Reply With Quote
Wooo tfung gone off deep end... EBMCS03 Off Topic Forum 4504 25th April 2011 22:04
IMPORTANT FOR E34 M5 OWNERS! Old M5 Messageboard Archive. Help Needed! Gustav E34 M5 Discussion 10 17th June 2010 04:19
German AMS magazine tests M5 suspension kits lofstrom E39 M5 and E52 Z8 Discussion 25 11th April 2008 12:24
BMW M5 culture over the net Rodrigo Feher E39 M5 and E52 Z8 Discussion 8 22nd December 2003 01:04
