Old 10th August 2000, 00:32   #1
SteveC
SteveC's Avatar
Garage: 850CSi
Post 3.8L throttle cutoff speed actuator
Hoping a knowledgeable 3.8L owner in Europe can shed some insight on the "cutoff speed" actuator.
My, I believe, is on the blink. Periodically while driving, I get a clinking noise which seems to emanate from under the dash, yet can be felt in the steering column. Then, shortly after the noises stop, the accelerator pedal resistance seems to disappear momentarily, with the sensation that unless you further depress the pedal about half an inch or more, there is no throttle control at all - like there is a complete dead spot in the linkage. Then all of a sudden, I think the actuator re-engages and because the accelerator is depressed slightly to compensate for the momentary dead spot, the engine revs up and the car zooms forward. Very spooky feeling.
So, exactly what is the purpose of the cutoff speed actuator? I assume it's part of the over-rev protection.
Is there any harm any disconnecting the actuator from the control box?
Any insights would be greatly appreciated.
SteveC is offline
Old 10th August 2000, 08:15   #2
BIMMER NUT
BIMMER NUT's Avatar
Garage: '93 M5T Daytona Violet
HEY STEVE:
HOW YA DOING?? I HAPPEN TO DISCONNECT MINE AS WELL AND HAVE NO PROBLEMS THAT ARISED FROM IT. I'VE HAD MINE DISCONNECTED NOW FOR A COUPLE OF 1,000 MILES. FROM WHAT I'VE HEARD IS, THAT ONLY THE EURO SPEC M5'S HAVE THIS KICK DOWN ACTUATOR. I KNOW THIS ISN'T EXACTLY WHAT YOU WANTED TO HEAR BUT IT'S A LITTLE INPUT ANYWAY.
PAUL
BIMMER NUT is offline
Old 26th August 2000, 12:03   #3
Alan Archer
Alan Archer's Avatar
Garage: M5 3.8 Diamond Black
Hi my friend !!
I am the man from europe with the 3.8 !!
Sounds like your limiter is playing up,
Look under the bonnet(hood) and locate the extra cable next to the main accelerator cable...it is held on by a puny white clip.
Take the ***** off !!
I bet the car will run normally now.. however if the noise gets to you, you'll have to get it checked out in the garage.
ps...this also removes the top speed limiter and lets you hit the rev limiter in top...enjoy!.
Alan Archer is offline
Old 4th December 2000, 15:56   #4
SteveC
SteveC's Avatar
Garage: 850CSi
I solved the problem this weekend.
The system in question is officially called "Top Speed Regulation" for the S38 B38, and has an internal BMW designiation of "VMX". This system consists of two components. The first one is the electro-mechanical throttle actuator which controls the throttle linkage. This part is visible on the left side (driver side) engine compartment, and has a connecting plug fitting immediately forward of the diagnostic plug. The second part is the VMX control module, which is located in the E-box.
I hooked up my Modic and did a diagnosis on the control module. The module returned gibberish characters and wouldn't return proper identification to the Modic, making is highly suspect as being defective. I installed the new control module and redid the diagnostic test. This time, the read-out was perfect, and I was able to activate the actuator and cycle it with the Modic. All operations were within specification, and contrary to my initial guess that the problem would be with the actuator, it turned out to be a defective control unit.
SteveC is offline
An in-depth SMG II review (LONG) kenneth E39 M5 and E52 Z8 Discussion 17 10th March 2004 01:31
From the Sunday Times Driving section...( long ) JJJ E39 M5 and E52 Z8 Discussion 13 12th July 2003 01:08
Hi speed driving jrturbo E34 M5 Discussion 2 30th September 2002 16:50
definition of a speed trap... Jacob Lee E39 M5 and E52 Z8 Discussion 1 7th February 2002 02:59
Go with throttle up! Max speed takeoff RPM ??? IvanDias E34 M5 Discussion 2 23rd November 2001 14:49
Page generated in 0.11447 seconds with 11 queries
