Old 7th July 2005, 03:15   #1
Infinicar
Garage: M5 3.6 Black M5 3.8 Black
Diff Ratio Identification
I have a couple of US customers who wants me to identify the ratio of the M5 diffs we have in stock.
I have had a quick look and can not see anything that resembles a ratio.
Anybody help?
Paul
www.infinicar.com
Breaking 2 x 3.8 E34 M5
Infinicar is offline
Old 7th July 2005, 11:07   #2
DrSakke
DrSakke's Avatar
Re: Diff Ratio Identification
Anybody help?
Paul
www.infinicar.com
Hi!!
There should be a part number on the diff, maybe the ratio is possible to check with that?
Of course it`s always possible to count the ratio by turning the driveshaft connector (???) and checking how many turns it takes to turn the outgoing thingys (ie. wheels)
Sakke
DrSakke is offline
Old 7th July 2005, 11:21   #3
farrell
farrell's Avatar
Sales Feedback: (4)
Anybody help?
Paul
www.infinicar.com
Paul
No marking will be on the hypoid casing. Std housing to suit various crown wheel & pinion ratios.
Apart from identifying the date of vehicle manufacture / vin no & therefore the ratio, the only other way is to measure the ratio yourself
Take one piece of chalk & mark the input flange (pinion) at 12 oclock.
Now mark the output flange at 12 oclock or insert a halfshaft & mark that.
Somehow, you will need to secure the hypoid on a bench or someone must hold it down
Using a tool to turn on the output end, turn the output flange one turn.
Someone with you can count the number of each turn the input flange makes, then using a dial gauge measure the percentage of the last turn the input flange makes, ie .68 or .72 of a complete input flange turn.
That wil be the ratio of the pinion & crownwheel.
Thats all I can think of.
Regards
Farrell
farrell is offline
Answers from Dinan, regarding rear diff. lockup ratio........... FAST 5 E39 M5 and E52 Z8 Discussion 0 25th November 2003 00:13
DINAN 3.45 rear diff. GROUP BUY is a Go! Info & Details............... FAST 5 M5 E39 Group Buy Forum and Sponsor Discussion and Offerings 20 11th November 2003 23:12
UPDATE: DINAN 3.45 rear diff. GROUP BUY info/details............... FAST 5 E39 M5 and E52 Z8 Discussion 15 23rd October 2003 05:51
Which diff ratio ?? madmax E39 M5 and E52 Z8 Discussion 6 13th July 2003 10:01
3.45 differential ? Black M5 Most Memorable Threads' 94 13th March 2001 00:16
Page generated in 0.12479 seconds with 11 queries
