Old 12th June 2000, 23:52   #1
SMB M5
Garage: 1991 BMW M5 Black/Gray
Post First track day of season (long)
Attended my first school of the season over the weekend at Watkins Glen run by the Genessee Valley Chapter and had a great time. The school was very well run and, as always, the track is spectacular. My car ('91 3.6) is set up with a Dinan Stage 2 suspension (Konis in front), RD strut tower brace, JC chip, Nurburgring front brakes (345 mm floating rotors/4 piston calipers) and UUC EVO SS. For track days I also install BFG R1 (old style) tires on the original factory wheels. Now for some observations, comments and questions.
1. With my suspension/tire combination the car handles very well on the track. Due to the size and weight of the car, it likes the larger tracks rather than smaller tracks with more turns and less straights.
2. For this track session, I installed a modified 1 piece exhaust system which runs from the header to the tips. The exhaust does not have catalyst and employs larger pipes, so it is much more free flowing. I didn't perform any other engine modifications to complement this exhaust and the result was a substantial loss in power throughout the rpm range. The car did not have any power coming out of the corners, particularly noticeable on the uphill portions. Also, on the way to the track I blew the left rear tire (fairly new Yokohama AVS S1) while doing about 80 mph. Upon removing the tire I noticed that the inner sidewall was completely demolished and saw that the exhaust pipes are very close to that tire (< 1") so I'm wondering if the heat from the pipe led to the tire damage. Before driving on the track, I wrapped that part of the exhaust with high temperature fiber and that seemed to help. For this reason, and the noise, I will probable switch back to my stock system.
3. Prior to installing the free flow exhaust, I also felt that the car seemed to have lost some of its mid range power. I had my mechanic run some tests but nothing seemed abnormal. All cylinders had a compression of at least 185 and all valves were within spec. The air intake resonance valve was also working correctly. Installed a new fuel filter and oxygen sensor but nothing seemed to remedy the situation. Could it be the ignition wires? Chip? I'm at a loss and I don't want my mechanic experimenting at $66 per hour. Any suggestions?
4. Switched from the UUC competition short shift to the street EVO model. The shifts are smoother with longer travel however, there seems to be a lot of "play" in the shifter. When in gear, I can move the shifter at least 1" to the right in any gear (don't know about 5th). Has anyone else experienced this? (Rob?)
5. Installed Porterfield R4 compound pads on the front and Mintex racing pads on the stock rear brakes. The pads and rotors held up well, but I still think that the stock front Textar pads give better feel and braking performance. For this reason, I'll probably use the stock pads for both the street and track.
6. My brake pedal seems too low when depressed for proper downshifting (ball of foot method). When I get on the brakes, the pedal is at least 1" below the level of the gas pedal. If I try to blip the gas with the right side of my foot, I have to let up on the brake to get leverage - not a good situation. I also noticed that when at rest, the brake pedal is below the clutch pedal. Does anyone else have this problem? Has anyone adjusted their brake pedal? I will have to perform this service myself as my mechanic does not want to for liability reasons.
This list is great, keep up the good work.
Steve B
91 M5
SMB M5 is offline
My track day at TWS last weekend pmiranda E39 M5 and E52 Z8 Discussion 14 23rd October 2002 06:53
First track day - LONG Vince5 Porsche 911 Turbo and Porsche Panamera Forum | panameraboard.com 10 9th September 2002 14:57
M5 Kicks Butt at Kyalami BMW track day richardk E39 M5 and E52 Z8 Discussion 12 24th April 2002 19:56
UK track day Sunday 25th November 2001 Bullit E28 M5 Discussion 0 10th September 2001 13:56
Lodging for M5 track day at Sears Point jlvink E39 M5 and E52 Z8 Discussion 0 26th July 2001 07:42
Page generated in 0.09765 seconds with 11 queries
