Old 16th May 2005, 00:08   #1
M5Wagon
M5Wagon's Avatar
Garage: 2007 E61 M5 Touring, 1986 E28 M5 (RHD #77)
Central Locking Problem - HELP !!
I've got a small problem with the car's central locking (six-speed E34) - would appreciate if anyone can advise on the problem/solution.
Story is this - the BMW 3G alarm is dormant, i haven't got round to getting a remote for this programmed yet so am locking/unlocking the car manually with the key. Here we go - key in the driver's door pops up the buttons and unlocks all the doors and boot but NOT the front passenger door, to let a passenger in i have to pull up the passenger button with my hand to unlock the door. To lock the car - key in the driver's door locks everything BAR the passenger front door which remains button up and unlocked. However, I note if i do the locking/unlocking from the passenger front door everything is fine, everything locks/unlocks, the problem only happens from the driver's door. And lastly this is sometimes sporadic - now and again it all works fine from the driver's door but only maybe 1 in 25 times!
Can anyone suggest the problem here - a fault at the driver's lock, a fault in the passenger's lock, or something to do with the central locking ECU which i think is somewhere on the car!
Obviously i'm keen to fix this myself (if possible!) and avoid the £72 per hour labour charge at local BMW agent.
Thanks for any suggestions.
M5Wagon is offline
Old 16th May 2005, 15:03   #2
jonsmiff
jonsmiff's Avatar
Garage: e39 m5 silverstone blue
Re: Central Locking Problem - HELP !!
sounds like a sticky c/l solenoid,try cleaning the connections on the solenoid
jonsmiff is offline
Old 16th May 2005, 15:39   #3
ECM4
ECM4's Avatar
Garage: E34 M5 3.8 6sp Kashmir Biege
I'd start off with the passenger door. Take the trim off and have a look at the solenoid. Determine if there's any life in it. If suspect then I'm sure we'd find an E34 in the Persley scrap yard. E34's are normally plentiful.
The other strong possibility is the wiring. From memory the door cable connects to the 'A' post via a multi-pin connector (under a rubber boot). My central locking problems have always been in this area. Its certainly worth a look for water ingress or corrosion.
I have a spare central locking ECU. Pop round if you want to try it however I have absolutely no idea where it lives on the M5 (it was bought for and E30).
Craig
ECM4 is offline
Old 16th May 2005, 22:20   #4
M5Wagon
M5Wagon's Avatar
Cheers guys - as suspected some investigation is required, no doubt it'll be something small. I'm right in the middle of a house move just now so will get round to it at some point, and Craig will catch up eventually to compare cars!
Cheers,
David.
M5Wagon is offline
Old 18th May 2005, 15:16   #5
Alan Archer
Alan Archer's Avatar
Garage: M5 3.8 Diamond Black
99% its just the door lock motor in the passenger door,
its straight foward to replace yourself, it just requires some
neat handywork to get inside the door !
Have changed a couple over the years on E34's, they're quite
a common failure.
regards,
Alan.
Alan Archer is offline
Old 22nd May 2005, 09:54   #6
UltimateM
UltimateM's Avatar
Garage: E34 M5 1990 RED
I had the same problem on my 1990 M5 -- it is LHD, but still the problem was with the passenger door.
After 2 hours of fiddling with the door card removed, some WD40 / RP7 (or whatever spray lubricant you use) and most importantly, a 2nd helper to be on the opposite side of the car, working the key in the door lock, all that was required was a little fine adjustment to the lock frame.
Be careful with the frequency of locking / unlocking, as if your helper deadlocks the door & activates the alarm mode (2nd position in lock) too many times quickly, the central locking will freeze for several minutes.
This is time to have a break and a drink/refreshment then back into it.
It was frustrating & awkward, but for some reason adjustment was needed, just 'a bee's appendage' worth of adjustment to be technical.
Now the central locking works as it should on all doors.
Moving house is NOT the right time to try to do this. Just be a gentleman for a little longer and unlock the 'passenger' door first !!
cheers.
UltimateM
UltimateM is offline
Old 24th May 2005, 00:18   #7
M5Wagon
M5Wagon's Avatar
Ha ha nice one UltimateM !! My high maintenance bint won't get in the car as A. it makes her feel sick and B. it's old. Women !!
I'll get the screwdrivers and WD40 out one weekend and see what happens !!
Cheers for the advice guys.
David.
M5Wagon is offline
Central Locking madness!!! Bader E34 M5 Discussion 14 1st July 2008 22:35
Terminal problem with my B10? B10Ken ALPINABoard.com | BMW Alpina Discussion 16 15th August 2004 22:03
Radio Problem Solved? paulbondy E39 M5 and E52 Z8 Discussion 9 7th August 2004 20:27
Brake Dust Problem wa1shy E39 M5 and E52 Z8 Discussion 1 14th June 2004 17:14
Vanos problem...an obvious problem which dealer says aint there..help needed Adam E39 M5 and E52 Z8 Discussion 10 24th July 2002 22:15
Page generated in 0.12317 seconds with 11 queries
