S38B36 catalyst melt - BMW M5 Forum and M6 Forums
 5Likes
post #1 of 25 Old 27th November 2016, 05:00 PM Thread Starter
Eero H
Eero H's Avatar
3.6 has two cats and both contain 3 ceramic cell. Because they are ~25years old, i've seen quite many 3.6 cats that drop black bits when upside down and tapped gently.
I crafted holes and took first cells out, both were destroyed. Second and last cell are ok. I will weld lids back, i think it will pass annual emission test with two working cells.
Car was fully working and passed emission test every year. I hope this do not make more noise, but lets see...
Eero H is online now
post #2 of 25 Old 13th March 2017, 01:50 PM Thread Starter
Eero H
Eero H's Avatar
post #3 of 25 Old 13th March 2017, 08:27 PM
Nikosx
Nikosx's Avatar
Nikosx is offline
post #4 of 25 Old 13th March 2017, 11:48 PM
6stang9
6stang9's Avatar
Great, something else to worry about....thanks a lot.
Now, I am thinking: since my car is over 25 years old, it does not need emissions testing... at least here in North Carolina.
Home of the Silver Bimmers: '99 E36, '98 E36, '91 M5, '84 Euro E24
6stang9 is offline
post #5 of 25 Old 14th March 2017, 06:28 AM Thread Starter
Eero H
Eero H's Avatar
Originally Posted by Nikosx View Post
Is the car any louder?
Very little metallic sound when pulled on full throttle. Idle or cruising i cant notice.
Straight pipes are way to go then?
post #6 of 25 Old 14th March 2017, 03:14 PM
GregT53
GregT53's Avatar
GregT53 is online now
post #7 of 25 Old 14th March 2017, 04:57 PM Thread Starter
Eero H
Eero H's Avatar
Originally Posted by GregT53 View Post
Going to straight pipes won't negatively affect back pressure and performance?
I had straight pipes, i feel it had less low rpm torq. I have seen some E28 M5 dyno numbers and shows straight pipes give little more hp on high rpm and less torq on low rpm.
OEM silencer is same size than cats, same power/torq numbers on factory brochures.
But why not just fix cats?
post #8 of 25 Old 18th March 2017, 12:15 AM
6stang9
6stang9's Avatar
You mean like you did? I can't, (I don't have time/skill) and I don't think I could find a shop that would touch a catalytic converter. Not okay to "mess" with emissions stuff, even if exempt from testing. But they could remove them.
If anything, yes, I would just delete the cats. :0
6stang9 is offline
post #9 of 25 Old 18th March 2017, 12:55 AM
inertia8
If in that situation, I'd just fit aftermarket metal cats with a lower cells per inch count, 100cpi or 200cpi.
inertia8 is offline
post #10 of 25 Old 18th March 2017, 07:43 AM Thread Starter
Eero H
Eero H's Avatar
That or install new cell inside. Removing cats are bad for enviroment you know.
That is one solution, problem is that it will look non original.
Proof that exotics won't melt! Dr.Know GTBoard.com: General Sportscars 8 29th January 2007 08:44 AM
Can CATALYST Sensor cause..... m5 rus E39 M5 and E52 Z8 Discussion 13 9th July 2004 11:25 AM
Snow Melt + M5 = ARRRGGG!!!! 1080iAddict E39 M5 and E52 Z8 Discussion 12 5th March 2003 10:09 PM
catalyst ? E34 M5 Discussion 6 20th February 2002 11:27 AM
Catalyst... kiwistu E34 M5 Discussion 2 13th May 2001 04:56 PM
