Old 7th May 2005, 11:18   #1
dalius
dalius's Avatar
Garage: m5 daytonaviolett-metallic
Send a message via Skype™ to dalius
water pump problem
hi .i need new water pump for 3.8 help!!!!thenks
dalius is offline
Old 7th May 2005, 12:47   #2
RAZ9922
RAZ9922's Avatar
Garage: M5 Touring Ferrari Red
Re: water pump problem
£164 incl. from BMW
This is a exchange unit, takes 4-5 days to order.
there is no gasket in the pack, so order this at the same time.
If you order one from germany over the internet:
A NEW Water pump is around £120 incl. postage.
and includes the gasket.
regards
RAZ9922 is offline
Old 7th May 2005, 16:04   #3
dalius
dalius's Avatar
Originally Posted by RAZ9922
£164 incl. from BMW
regards
how to orderit from bmw for 164£. in london its 250£.
dalius is offline
Old 7th May 2005, 16:06   #4
dalius
dalius's Avatar
£164 incl. from BMW
regards
and how to orderit from germany?
dalius is offline
Old 7th May 2005, 16:07   #5
dalius
dalius's Avatar
help!!!!!
dalius is offline
Old 7th May 2005, 16:35   #6
RAZ9922
RAZ9922's Avatar
Got it here
Wood in Salisbury
London Road
Salisbury
Wiltshire SP1 3YU Tel: (01722) 325 325
Fax: (01722) 333 831
Email: wis@woodbmw.co.uk
£164 exchange
£250 must include fitting?
Water pump is an easy job.
only special toll needet is the spanner to take the viscus coupling of (£8 from halfords) Viscus has a left hand tread by the way.
Rest are just 10mm socket.
Childs play :p
Hope that helps
regards
RAZ9922 is offline
Old 8th May 2005, 04:54   #7
WylM5
WylM5's Avatar
Garage: 91 E34M5 01E39M5
Got it here
Wood in Salisbury
London Road
Salisbury
£164 exchange
Childs play :p
Hope that helps
regards
Actually you will also need a VERY thin wrench to take off the fan coupling nut. You can get away without the spanner ( BMW tool 11 5 030)if you have a couple of box end wrenches but if you can get one for cheap it would make the job faster. If you are doing this yourself do not forget the gasket and to get new bolts as some of the old ones on mine were a bit rusted. You also might as well change the belts at this time as they are all going to have to be removed. Hope this helps
Wyl
1991 E34 M5
Dinan Stage III Suspension///Dinan Chip
Brembo Cross Drilled Rotors///HRE 340 Rims
Supersprint Exhaust///UUC Short Shifter
____________________________________
2001 E39 M5
Dinan Front and Rear Brace///Dinan Software///Dinan Differential///Dinan Rear Swaybar///BP Sway bar braket
///Tubi Exhaust
Brembo Front brake kit///UUC Short Shifter///UUC Clutch + Lightweight Flywheel///Rouge Engineering Tranny Mounts///UF Motorsports IATS
///Koni front + rear
WylM5 is offline
Old 8th May 2005, 16:25   #8
dalius
dalius's Avatar
Wyl
big thenks
dalius is offline
Kat warming pump..... Jahangeer E34 M5 Discussion 39 18th May 2006 18:49
Water pump issues enjoymentman E34 M5 Discussion 11 19th March 2006 21:41
Vanos problem ilundber E39 M5 and E52 Z8 Discussion 15 3rd November 2005 01:30
Loose Oil Pump Bolts...... Lscman E39 M5 and E52 Z8 Discussion 2 27th March 2005 20:43
Terminal problem with my B10? B10Ken ALPINABoard.com | BMW Alpina Discussion 16 15th August 2004 22:03
Page generated in 0.13918 seconds with 11 queries
