Old 27th April 2005, 22:43   #1
gary morgan
Garage: 3.8 avus blue
over revving
hi boys, need some help if poss, nearly every time i start the car it over revs i turn it off try again and it revs ok, does not rev quite so high when hot but the problems still there By the way if anyone who was at the last meet remembers the hot rod it only cost me 26 quid to sort the sls
gary morgan is offline
Old 28th April 2005, 09:21   #2
DrSakke
DrSakke's Avatar
Re: over revving
HI!
Do you mean that the car revs without giving it any throttle at start?
In that case I would suspect Throttle wire thats stuck(check the throttle position in the engine bay before start)
What car do you have? 3,8 or 3,6?
Could be something in the electronic bits also but can`t really help you there. Somebody else?
But it definitely sounds like that the throttle is open or gets opened at start, otherwise it wouldn`t rev that hard, or would it?
Sakke
DrSakke is offline
Old 28th April 2005, 11:02   #3
Jahangeer
Jahangeer's Avatar
Garage: .................
Re: over revving
I had a similarish problem when the car was hot the engine revved high on idle - got a new O2 sensor - hey presto fixed.
Rgds
J
Regards
J
Jahangeer is offline
Old 28th April 2005, 11:55   #4
WylM5
WylM5's Avatar
Garage: 91 E34M5 01E39M5
Re: over revving
Have your shop check the Trottle position switch. If it's starting to go it can lead to all kinds of funky problems.
Regards
1991 E34 M5
Dinan Stage III Suspension///Dinan Chip
Brembo Cross Drilled Rotors///HRE 340 Rims
Supersprint Exhaust///UUC Short Shifter
____________________________________
2001 E39 M5
Dinan Front and Rear Brace///Dinan Software///Dinan Differential///Dinan Rear Swaybar///BP Sway bar braket
///Tubi Exhaust
Brembo Front brake kit///UUC Short Shifter///UUC Clutch + Lightweight Flywheel///Rouge Engineering Tranny Mounts///UF Motorsports IATS
///Koni front + rear
WylM5 is offline
Two fast Volvos: S40 and 850 revving to 9000 rpm Gustav GTBoard.com: General Sportscars 4 26th May 2004 23:33
Slow revving M5 !!!! Ahmed E39 M5 and E52 Z8 Discussion 4 26th May 2004 14:49
[*Video*] Revving a 523iA -96 *serious competitor* Fin535dA GTBoard.com: General Sportscars 0 31st August 2003 00:49
Vid: Kelleners exhaust revving BostonRocket E39 M5 and E52 Z8 Discussion 33 27th April 2003 01:34
Video of me revving my exhaust (eisenmann + Xpipe) SWing E39 M5 and E52 Z8 Discussion 34 27th August 2002 21:32
Page generated in 0.10345 seconds with 11 queries
