Re: Issues
V-Belts should have been changed every two years or so with the Inspection 2 anyway says my local independant.
Oil cover gasket leaks are common on these cars. Smoetime just a *small* tightening of the bolts will do, otherwise leave it until you need timing chains or engine out job.
An oil leak from here will occur simply from age, also from using oil too thin. Remember a weigfht of 0sw-whatever is too thin, recommend 10sw or 15sw-whatever. A good 10sw40 or 15sw40 should be fine.
Oviously it should not be leaking loads, as in drip-drip-drip, big patch overnight, but an occasional drop and dirt and oil around the gasket is surprising common on most 3.6 cars and the "rougher" of the 3,8s.
Therefore also worth cheaking yourself whether the oil pipe is corroded or definately faulty.
Low oil warning is B A D !!
Have you checked the level? It may just be the sensor. If low, make sure you fill it up and monitor it to tell whether a major leak or just low.
Front suspension takes a bashin, so always expect bushes and rods etc to need doing on the front. Your service history should tell you when or if they were done in the past.
Your service history should show how many miles the clutch has done. I`ve not yet (!) killed the M5s clutch, but when the 535i one went, I literally got 2 to 3 miles of grinding as the throwout bearing died, and 2 miles to the garage.
If it slips, don`t drive it more than (survey says) 20-50miles, otherwise the unit may disintegrate and damage the flywheel assembly, which means $$$.
Propshaft donut is every 100,000miles or so?
Hope this helps.
Ivan.
