Hi
So I have E36 with S38B38 swap the car is runing well but I noticed that EGT goes way too high - 1460 F + ( 800degrees C ) that is on WOT and IF I drive at about 20% TPS with 4000rpm on second gear . I thing that this temperature is not normall for n/a BMW engine . The AFR is 12.5:1 , compression on each cylinder is perfect 15bar flat ( stock 14,5-15) all sensors are OK , valve clearence is exact that must be . So i think that there is something that cuts the ignition timing and raize the EGT . That thougth came to me when I did not hear detonation when use low octane fuel ( I am with Jim C chip ) , also I tried stock sparkplugs and Desno iridium IXU22 no difference ...
Please tell me what may be the problem that make the ECU to cut the timing ( there is no knock correction on S38B38 engine )
