Old 20th April 2005, 22:26   #1
Cyrus
Garage: BMW E34 M5 3.8 Avus Blue
3.8 Engine Problems
Why do so many 3.8's blow up?
Every month I read another 3.8 has put a ole in the side of the block.
Why is this?
Aso, alot of 3.8's seem to go wrong alot more than the 3.6's.
Why is this?
Cyrus is offline
Old 20th April 2005, 23:30   #2
kris
kris's Avatar
Garage: '93 M5 DAYTONA VIOLETT
Re: 3.8 Engine Problems
Why is this?
Why is this?
Probably rod bearings, only after 50K miles: http://www.e12m535i.com/E34_M5/images/rod_bearings/
http://autos.groups.yahoo.com/group/.../message/42704
'93 M5 DaytonaViolett 3.6L 225+K miles
kris is offline
Old 21st April 2005, 00:32   #3
M5touring reg
M5touring reg's Avatar
Garage: 95B M5touring Avusblau,met.
Why is this?
Why is this?
hearsay and rumours, normally it is the driver/owner who is the problem and not the engine -
it just might be that the 3.8 is a little less forgiving to -incorrect- treatment like 'pedal to the metal' with low oil-temp etc. and needs a little more care
with warming up AND cooling down BUT with proper treatment and that
INCLUDES HARD DRIVING the engine will hold, there are cars out there with
400.000 km - also the rpm-limiter does NOT work at down-shift, i.e. down-shift from 5th to 2nd in high speed is NOT a good idea, it can happen to the best though
Karl / Global E34 M5touring Registry
M5touring reg is offline
Old 21st April 2005, 00:47   #4
Pepsmeister
Garage: 1995 BMW M5 Shadowline
The 3.6 is considered more reliable because it is less tweaked. The distance between essential parts of the motor are greater than in the 3.8, and this means that the 3.6 has a greater "screw-up safety margin".
Still, when you hear of the 3.8s getting busted, it is usually because of maintenance carelessness of either the owner or the owner before him...
The 3.8s are more sensitive to maintenance. However, as long as this is carried out properly, these engines should not be a problem and are good for a couple of hundred thousand miles.
1995 BMW M5 Schwarz II Shadowline
Dr. Schrick camshafts
UUC Short-shifter
Pepsmeister is offline
Old 21st April 2005, 12:37   #5
Bryn
Garage: BMW M5, Black, 1993, 3.8
Why is this?
Why is this?
Where are you hearing of these incidents?
In 4 years of ownership I've only seen/heard of a handful of terminal engine problems with the 3.8.
Nothing compared with the number of E39 M5/E46 M3 engines that are being rebuilt/replaced.
I think the general consensus is that they are very reliable.
Cheers,
Bryn.
'00 B12 6.0 LWB
'96 728i B12 Replica
'94 Porsche 993 race car
'93 M5
'92 Integrale Evo 1 Martini
'91 B10 Bi-Turbo
'89 325i Sport
Bryn is offline
Old 21st April 2005, 13:54   #6
Phlem5
Garage: 92 3.8, 5sp, Avus Blue(SOLD) & 95 LE 25/50
Just out of interest I was at the dealers yesterday and I priced an engine, complete less ancilliaries - £8000 odd plus VAT, inc 15% mark up.
I'm just going to top up my oil ! inspection 2 might be in order as well.
cheers,
Phil.
Phlem5 is offline
Old 21st April 2005, 13:57   #7
Mmm-Five
cheers,
Phil.
Mine had a new engine, gearbox, exhaust system about 80,000 miles ago due to BMW 'technician' error.
The total bill including VAT and labour (£80/hr) was £22k - at today's labour rates (£120/hr) I could see it being closer to £25k!
2006 e86 Z4MC (überkart)
http://mmm-five.net/
Mmm-Five is offline
Press Release no 2: The new V10 Power Unit in the BMW M6: A Masterpiece in Engine... Gustav E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 0 15th December 2004 01:15
Nowack Tuning Report, The Truth (Long Version) CharlesW Most Memorable Threads' 44 30th November 2002 05:49
3.6 owner meets a 3.8 car... IvanDias E34 M5 Discussion 16 9th April 2002 10:57
Break In period Joe Lapicki E39 M5 and E52 Z8 Discussion 21 29th March 2001 22:23
Rough idle on S38 M5 3.8 - buying advice - Speedy E34 M5 Discussion 2 4th May 2000 20:26
Page generated in 0.13742 seconds with 11 queries
