Old 19th April 2005, 23:10   #1
Cyrus
Garage: BMW E34 M5 3.8 Avus Blue
Changing suspension on 3.6
I want to slightly reduce the ride height on my 3.6
Im also experiencing a very bouncy ride and the car doesnt handle very well and rolls too much.
So Ive decided I want a different setup altogether. My last M5 had the same thing and it had brand new suspension. I hated it in all honesty.
Whats out there for 3.6 M5's?
Shall i change just th springs or do the shocks aswell?
Cyrus is offline
Old 20th April 2005, 15:24   #2
ste
Garage: e34 M5 3.6 (Macau Blue)
Re: Changing suspension on 3.6
I though the one I sold to you handled and rode very well. You have to remember it's a big heavy car dude and isn't going to be spankable like your e30 M3. Maybe consider the touring rear ARB before you go ditching the whole standard set up? You'll get less roll, less understeer and a more pointy front end. You won't sacrifice ride or comfort either. Maybe consider some negative camber on the front too? This should reduce understeer and make it pointier still. I think BMW do camber correction top mounts. If I remember correctly you can fit these the wrong way round and gain about 1° negative. Otherwise you'll have to look at adjustable top mounts from Ground Control or similar.
If you decide to go the whole hog I'd forget a spring and damper kit and look straight towards proper coilovers. I'm not sure how you'd integrate the SLS though - I imagine you'd have to discard it.
You're welcome to have a go of my car when you're over next - it's got lowering springs on it and it rides like a pig. It'll put you off straight away.
KRAFTWERK
ste is offline
Old 20th April 2005, 15:26   #3
farrell
farrell's Avatar
Sales Feedback: (4)
Hi Cyrus
Can you put your finger on exactly what you dont like about the setup.
Is it the front or rear end behaviour. Your car still has self levelling rears.
Is the ride height at the rear set correctly ?
It makes a difference especially in damp conditions.
Lowering one of these things much further than BMW Intended can make their handling twitchy in the wet & the crashes & bangs get worse as more of the jounce (compression) is removed as the damper movement is also reduced.
However, if you were to go to a full coilover spring & damper setup with adjustable top mounts and adjustable front lower arms, you could set the car up & still maintain a good tyre contact patch on all corners.
Lowering can increase wear to the inside edges of the tyres unless consideration is given to the above.
To my knowledge , there is no tailor made coilover kit made by any manufacturer in Europe. A system can be made to fit wth appropriate internal valving to suit the cars characteristics & intended use.
It is all possible as I met a fella at the Nring who had his 3.6 all stripped & lowered with coilovers all round.
It went like stink & handled like a race car, which it basically was.
MONEY... MONEY... MONEY... MONEY... MONEY..OH & MORE MONEY !
Good luck Mate
Farrell
farrell is offline
Old 20th April 2005, 17:34   #4
Cyrus
I'm glad you guys know what your talking about otherwise I might have ended up wasting my money.
I want the car to sit a bit lower than it is now.
I dont like the way it rolls, both of them do this and I keep thinking its going to fall over.
I dont like the bouncy castle effect on motorways and yes my tyres pressures are fine.
I want flatter cornering.
The most annoying thing is the roll.
So, less roll and if its possible lower ride height.
Sal
Cyrus is offline
Old 20th April 2005, 17:52   #5
cchase009
Garage: E34 M5 Black
Farrell, what setup are you running? Sounds like you are stock. I'm curious because I'm at the crossroads with suspension and I am seriously considering going back with SLS. I'm new to the M5 but I can tell the suspension needs refreshing. All these option flying around, Dinan Stage III, Coilovers, makes it hard to choose.
So what does ride like a pig mean? Is that good?
Originally Posted by farrell
Hi Cyrus
Good luck Mate
Farrell
cchase009 is offline
Old 20th April 2005, 18:44   #6
farrell
farrell's Avatar
Sales Feedback: (4)
Sal
Hi Cyrus
How old are your springs & Dampers ?
What condition are roll bar & bushes / brackets in ?
Metals fatigue at varying rates dependant upon the composition & treatment
& environment in which they live & work.
Im going to be controversial here & give an example that may concern some.
Take a new vehicle and perform a front end impact test at 50 kph.
Wow, excellent the safety cell remains intact, everyone is fine and all walk away. Hello Ncap 5 star rating.
Now take the same vehicle thats spent 10 yrs in the real world with extremes of temperature and 150,000 on the clock etc & do the same test.
Oh effin ell...the drivers got the clutch pedal stuck in his leg & the doors wont open. It all looked ok but metals, plastics etc all succumb to fatigue in one way or another
Your anti-sway bars or roll bars as you like, are under tremendous momentary transitional bending & torsional (twisting) forces.
They are mounted to the body via a bushing & bracket arrangement.
The whole assembly inclusive of roll bars are scrap by 150,00 km
Please dont consider lowering your car. that will lower the centre of gravity
and make the car more stable as there is less air moving under the vehicle.. but my not deal directly with your main problem... ROLL.
It may also make your ride more crashy & bumpy.
My advice for what it is worth is to go get a Touring rear roll bar & bushes.
a front roll bar & some bushes & bolt them on.
If your springs & dampers are as you say, then I will eat my Bosch Automotive handbook if this does not improve on your concerns.
Is that a deal...?
Regards
Farrell
farrell is offline
Old 20th April 2005, 19:06   #7
Cyrus
Ok i promise not to lower the car because I know your right about the ride and all the tyre wear issues.
I agree that metals and plastics undergo massive stresses and after a certain amount of abuse metal fatigue comes into play.
Looks like im looking for some ARB + bushes then! Hartge recommend I use Poly bushes for the ARB's, what you think?
Does anyone have the part numbers for the springs and dampers by any chance for a 3.6? I want to check if they put the right stuff on the older car which apprently has brand new everything. Both cars handle and roll exactly the same. The ride is the same aswell.
I have no idea if the dampers or shocks have been changed on the newer car though. Willl go through the 1 million pieces of service history to find out.
Cyrus is offline
Old 20th April 2005, 21:51   #8
farrell
farrell's Avatar
Sales Feedback: (4)
Cyrus
I would recommend putting the car on a hoist & checking wear on the suspension arms & things like rr beam mounts.
Roll bars & bushes will need changing.
Polyeurathane bushes distort less & last longer but transmit more vibration & noise to the body. Choose your compromise...
Hartge are good parts.
I have outlayed huge amounts over the yrs on suspension parts, not just EDC dampers. Everything deteriorates gradually, then bam, its all over the shop.
Take care
Farrell
farrell is offline
Old 20th April 2005, 22:18   #9
Cyrus
Ive had Bexleys under the car already, all the arms, balljoints, subframe bushes, tie rods were fine. I dont think they looked at the anti roll bar bushes though.
To be honest I dont think they are worn, I just dont like the roll the car has. Maybe Im too used to having very little roll due to the M3 I had and the e30 C2 2.7 Alpina I had which were almost roll free. Very very flat.
The handling to be honest is very good for such a big car.
Am I asking too much from a big 1800kg machine?
Cyrus is offline
Old 21st April 2005, 10:20   #10
Mmm-Five
If it rolls this much then it is normal!
2006 e86 Z4MC (überkart)
http://mmm-five.net/
Mmm-Five is offline
Question about the corvette and suspension in general? paulh GTBoard.com: General Sportscars 1 10th March 2005 18:51
3.6 Suspension and Ride Quailty Cyrus E34 M5 Discussion 3 25th November 2004 20:17
Press Release 4: The suspension of the M5: Ensuring a high degree of agility Gustav E60 M5 and E61 M5 Touring Discussion 0 4th July 2004 22:03
Press Release 4: The suspension of the M5: Ensuring a high degree of agility Gustav Most Memorable Threads' 0 4th July 2004 22:03
3.6 owner meets a 3.8 car... IvanDias E34 M5 Discussion 16 9th April 2002 10:57
Page generated in 0.19689 seconds with 11 queries
