Old 18th April 2005, 00:37   #1
EBMCS
EBMCS's Avatar
Garage: E34 M5 White
Oil leak problem
Hi,
I noticed my 93 has developed a slow oil leak shortly after I did my own oil change. Since I just picked up the car about 6 months ago, I don't know what grade of oil was in the car. I replaced it with 15W-50 Mobil 1. The oil seems to be leaking towards the back of the engine block. Had the car up on the lift and couldn't pinpoint exactly where the leak is coming from. If I park the car and it drips about 2-3 drops in an hour. Am I using the right grade of oil? Where should I be looking?
Thanks,
Paul
EBMCS is offline
Old 18th April 2005, 13:59   #2
yewcorner
yewcorner's Avatar
Garage: E60 M5 Interlagos Blue
Re: Oil leak problem
Oil is fine, the original spec was 15w40, I'm currently using 15w50 Silkolene and I know of least one of the members using Amsoil 20w50 which I think I'm going to use next.
I believe your oil leak is coming from either the rocker cover gasket or your sump gasket, they both seem to be a common source of oil leaks.
The rocker cover gasket is simple to replace; The sump is another story, it involves lifting the engine and manipulating the gasket in from there
Originally Posted by EBMCS
Hi,
Thanks,
Paul
2005 E60 M5 Interlagos blue
yewcorner is offline
Old 19th April 2005, 19:24   #3
EBMCS
EBMCS's Avatar
I hope it's not the more complicated one. I don't really have the time to have my car in the shop for a few days. I use my car as a daily driver. It's an awesome car.
EBMCS is offline
Old 21st April 2005, 23:43   #4
day
Garage: E34 M5 - granite silver
You could also check the tightness of the sump bolts. I had a few oil leaks and replacing the cam cover gasket and tightening up the sump bolts (some of which were really loose) seems to have sorted it.
day is offline
Severe Oil Leak!!! Yangi E34 M5 Discussion 8 7th November 2004 19:25
Help - oil leak! MikeyH E34 M5 Discussion 6 29th March 2004 11:09
oil leak again durt E34 M5 Discussion 10 1st February 2003 07:23
help - oil leak !!!!!!! durt E34 M5 Discussion 4 27th January 2003 17:32
Nowack Tuning Report, The Truth (Long Version) CharlesW Most Memorable Threads' 44 30th November 2002 05:49
Page generated in 0.10516 seconds with 11 queries
