Old 17th April 2005, 17:19   #1
jamilor
Garage: 1991 3.6L M5 Jet Black
Starting Problems
Hello,
Problem starting a 1991 E34 M5. From the research I've done it seems the problem might be a bad ground from the engine to the chassis. I turn the key and the car won't start, but if I keep the key turned after about 10-20 seconds the car finally starts right away. It seems to get worse after a hot day. I'm not a mechanic so I'd like some opinions from the experts. Any other ideas of what the issue could be or am I on the right track? Also is replacing these wires relatively straight-forward? Thank you.
jamilor is offline
Old 17th April 2005, 22:01   #2
Stevie
Stevie's Avatar
Garage: e34 540i, Orientblau
Re: Starting Problems
Funny: I have the same problem! If the car has been shut down shortly after idling while (fuel/smoke-stop right after "no darling, I'm not spending the night here to find myself in 2,5 hours of traffic in the morning, so MOVE!!!") it won't turn over. When the key is inserted and the car started immediately it will also take 3 or 4 seconds before the starter engages, but if you turn on the ignition, wait 2 secs (seatbelt, put phone in cradle, etc) it will engage the starter immediately after twisting the key further....... I'm puzzled!!!!!
Originally Posted by jamilor
Hello,
Dragracing a BMW is like taking Jessica Alba fishing. Some might considering it fun, but think of what they missed....
Stevie is offline
Old 18th April 2005, 22:39   #3
enjoymentman
enjoymentman's Avatar
Garage: E34 m5 1993 Euro Daytona Violet
Send a message via Yahoo to enjoymentman
could be your fuel pump is going south
enjoymentman
'93 3.8
enjoymentman is offline
Old 19th April 2005, 13:53   #4
ilundber
ilundber's Avatar
Garage: 1991 M5 Lagunengrunmetallic and 2001 M5 Le Mans Blue
If the engine turns when you try to start it but doesn't fire up, I would guess that the fuel pump in unable to deliver fuel at the right pressure to release the fule valve or the fuel release valve does not open. The fuel valve is located ath the very front of the fuel line, on top of the engine and if memory serves me right, there is a vacuum hose connected to it.
If that hose, or any other hose in the vacuum system is damaged, you may not get enough vacuum to open the valve. This may be caused by heat, tear and wear.
ilundber is offline
Old 20th April 2005, 03:23   #5
WylM5
WylM5's Avatar
Garage: 91 E34M5 01E39M5
My car had a leak in the fuel line. Symptoms were that the car would start up as normal immediately after being shut down but if a few hours past the engine would turn for a couple of seconds until the fuel pump was finally able to refill the now empty fuel line.
It's probably a good idea to have all your fuel lines checked out just in case considering the age of our cars.
1991 E34 M5
Dinan Stage III Suspension///Dinan Chip
Brembo Cross Drilled Rotors///HRE 340 Rims
Supersprint Exhaust///UUC Short Shifter
____________________________________
2001 E39 M5
Dinan Front and Rear Brace///Dinan Software///Dinan Differential///Dinan Rear Swaybar///BP Sway bar braket
///Tubi Exhaust
Brembo Front brake kit///UUC Short Shifter///UUC Clutch + Lightweight Flywheel///Rouge Engineering Tranny Mounts///UF Motorsports IATS
///Koni front + rear
WylM5 is offline
Old 20th April 2005, 14:44   #6
M5touring reg
M5touring reg's Avatar
Garage: 95B M5touring Avusblau,met.
on a 3.6 M5 the distributor is a common (and cheap to fix) problem -
open and check before you invest any money or time otherwise
good luck !
Karl / Global E34 M5touring Registry
M5touring reg is offline
Old 20th April 2005, 15:05   #7
unesential
Garage: 1991 M5 black
Send a message via AIM to unesential
Sounds like a faulty starter relay. They can get sticky when hot.
unesential is offline
Old 20th April 2005, 20:39   #8
Cor-Jan
Cor-Jan's Avatar
Garage: alpina b10 bi-turbo DAYTONA-VIOLET
Hello,
The problems with my BT started like that.Then it got worse and worse.My advice; check the cranksensor.
Wenn der Alpina im Ruckspiegel auftaucht,gibt es kein entrinnen.
B10-BT nr.360 "The Dazzler"
Cor-Jan is offline
Old 22nd April 2005, 16:24   #9
jamilor
Thanks for the replies,
Actually the symptoms are like this:
I turn the key and nothing happens. The engine doesn't even try to start. Then a few seconds later it fires up with no problem. Sometimes it takes if longer then a few seconds for anything to happen. Once I couldn't get it to start at all. I'll look into all the things you mentioned.
jamilor is offline
Old 26th April 2005, 22:56   #10
day
Garage: E34 M5 - granite silver
I wonder if this is the problem I had? You would turn the key but the starter wouldn't run. If so, it turned out to be the relay that operates the starter solenoid - I think it was a yellow topped one under the cover where the ECU lives.
day is offline
E28 electrical problems...help needed!!! ALPINA B9-06 ALPINABoard.com | BMW Alpina Discussion 3 4th January 2005 20:06
Bi-Turbo starting problems solved Cor-Jan ALPINABoard.com | BMW Alpina Discussion 3 5th July 2004 00:50
serious starting problems Cor-Jan E34 M5 Discussion 0 18th June 2004 13:36
Trip to Nordschleife/Brake problems solved johann E39 M5 and E52 Z8 Discussion 20 19th July 2002 21:36
Is BMW loosing it? Severe technical problems w new 7! Black B10V8 E39 M5 and E52 Z8 Discussion 23 17th January 2002 09:48
Page generated in 0.16942 seconds with 11 queries
