Originally Posted by QSZ
I am wondering if anybody has had this problem and can be of help.
I was at a track day last Sunday and my 3.6 just started to run extremely rough to the point I couldn't make it back to the pits area. Towing the M5 to the pits was not a good look
It is over fuelling and running the injectors to full duty cycle. Have checked all sensors/MAF and it looks like the ECU has some issue. Can anybody shed some light on this for me?
Thanks,
Simon
Hi there QSZ
Dont start panicking yet. Its easy to think the worst with these old girls & Brian has raised some fair points.
Are the spark plugs & leads ok ? (Just checking) A track day can punish the plugs.
I would get the DME fault codes read as a starting point.
I would then guess that the fault will not lie with the engine management but with either the engine side water temp sender giving a false reading to the DME & putting the car into cold start strategy. This can be the sensor or the cooked wiring that becomes embrittled due to 10 yrs of Upheat.
Next up is the Oxygen sensor gone down which is far from unusual. Either way the fuelling will be shot with either option. Brittle wiring & cooked connectors has been a issue with my car in the last yr or so.
Things to fix start becoming more expensive after these two checks but assuming the DME is ok, this should point you in the right direction.
These cars can survive a track day, even the most punishing circuits like Nurburgring or Bathhurst as a comparison for the Southern Hemisphere can be fine as long as do a couple of laps & let the car cool down before going again.
There are far better choices for track cars & 1.7 odd metric tonnes does take its toll on the underpinings. Only a personal view mind you so not worth more than that.
Regards
Farrell
