Old 15th April 2005, 12:34   #1
Smokestack
Smokestack's Avatar
Garage: 6 sp M5 Touring Stirling Silver
EDC NOT ACTIVE
Any ideas anyone?
I'm getting an intermittent 'EDC NOT ACTIVE' warning. This happened following new rear subframe bushings being fitted and a SLS wiring fault being
repaired. See this thread for more info - Time to let my M5 Touring go?????
Suggested causes are the EDC ECU. But, I'm not convinced! Too much coincidence for my liking.
Any help greatly appreciated as always!
Smokestack is offline
Old 15th April 2005, 16:42   #2
farrell
farrell's Avatar
Sales Feedback: (4)
Re: EDC NOT ACTIVE
Originally Posted by Smokestack
Any ideas anyone?
Smokestack
Id be very suspicious of wiring to the rear dampers. The wiring under the rear seat can get chaffed & where the harness exits out of the rear seat floor bulkhead behind the battery can get damaged to. The wiring harness runs out nr the rear subframe & gets chaffed with the obvious problems & sometimes the fuel pump wiring can also get damaged here with poor or no fuelling as it runs within the same harness bundle.
Those EDC controllers dont tend to go wrong very much, though I accept that a couple of the forum members have changed them recently.
No Guarantees here but I would check around these areas first.
Regards
Farrell
farrell is offline
Old 15th April 2005, 16:45   #3
M5 powered
Garage: M5 limited edition (02/50) Rosso Red
Re: EDC NOT ACTIVE
Originally Posted by farrell
Smokestack
Regards
Farrell
I'm 99% sure you will find it is the cabling. In order to get EDC not Active warning, the EDC CPU has to be working to diagnose.
1995 M5 Limited Edition (02/50)Rosso Red
Pilot Sport 2 Rubber
Valentine One With Conceal
Twin Head LRC100 IR Jammer System
Origin Blue B2 GPS
M5 powered is offline
Old 15th April 2005, 18:00   #4
Smokestack
Smokestack's Avatar
Re: EDC NOT ACTIVE
Thanks for that M5 Powered and Farrell. Just what I was thinking. Absolutely, the CPU either works or not in my view.
I was watching my mechanic tug the harness around when the SLS fix was made!
EDC Dampers Rebuilt! Perfect! Pepsmeister E34 M5 Discussion 19 24th March 2008 00:32
The E60 Active Steering Blues CSBM5 E60 M5 and E61 M5 Touring Discussion 29 31st December 2005 04:29
Impending EDC Failure ? FinalEditionE34M5 E34 M5 Discussion 17 19th January 2004 20:20
E60's active steering, from AutoBild :) Micsor/DK E60 M5 and E61 M5 Touring Discussion 2 23rd August 2002 23:24
Page generated in 0.10665 seconds with 11 queries
