Old 13th April 2005, 17:30   #1
Nuno Miguel
Garage: Bmw e34 3.6 M5 Red
Need serious help on Gearbox issue...
Hi, i got my gearboxbox "rebuild" (the problem was 3rd clash), the job consisted in replacing the 2th, 3rd and 4th syncro rings, all bearings, joints and some minor parts. It was made by a experient mecanic. All gears shift very well, but at some moment the 4th gear, jumped... (with out scratching) and so on, since then at aprox 90/10km/h it always jumps (only the 4th)... my mecanic was very surprised... and said that it only could be two things, 1º the compresion springs that he didnt change (he already made the order) and the 2º could be the GEARSHIFT ROD JOINT that he changed, but the new one from BMW was slight diferent from the original one... bmw said it has been improveed (???)
2 days later, all cheked... Gearshift rod joint as the same measurments, the compression springs changed, "bearing, shift lever" changed and...
4th gear jumps no more, but instead it does not engage at medium revs, on the other hand, at high revs it does it very well, for ex: in acelaration shift from 3rd to 4th driving at 120km/h or more... no problem, at speeds lower then 120km/h (in 3th) engage 4th is impossible... it doesnt stratch it slimply doesnt complete the movement, when you try to shift it, the knob starts to shake, at speeds below 30km/h shifting is possible again...
Shifting from 5th to 4th same thing... at speeds like 175/180km/h no problem change from 5th to 4th, but (ex.) at speeds of 100km/h its impossible to reduce gear (5»4)
My mecanic wont open the gerbox again until he gets the bmw repair Manual and said to drive the car like this to see if there is any improvement.
Any opinions?
GUIDE SLEEVE 3RD AND 4TH GEAR?
DRIVE SHAFT
(cant find "4th gear shift gear" on bmw parts database, it seams it is on the drive shaft, is it?)
Does any one has the BMW repair manual for the gearbox (getrag 280)?
Bmw Portugal doesnt have it...
You can imagine how i am feeling... i just speent +/- 1500 dollars whit this result... and i had to count all cents!!!
Nuno Miguel is offline
Old 14th April 2005, 04:57   #2
WylM5
WylM5's Avatar
Garage: 91 E34M5 01E39M5
Re: Need serious help on Gearbox issue...
That really sucks big time Miguel. I know how frustrating it can be to not have her running perfectly. The only info I can forward to you is a guy that has a good reputation on rebuilding these transmitions in the USA. His contact info is below.
Jim Blanton
Blanton Transmissions, Inc.
jblanton@sky.net
1427 West 9th Street
Kansas City, MO 64101
816-221-8584
Info is from BMWE34M5.COM Since you live in Portugal maybe he will just help you out as he really won't be losing any business.
1991 E34 M5
Dinan Stage III Suspension///Dinan Chip
Brembo Cross Drilled Rotors///HRE 340 Rims
Supersprint Exhaust///UUC Short Shifter
____________________________________
2001 E39 M5
Dinan Front and Rear Brace///Dinan Software///Dinan Differential///Dinan Rear Swaybar///BP Sway bar braket
///Tubi Exhaust
Brembo Front brake kit///UUC Short Shifter///UUC Clutch + Lightweight Flywheel///Rouge Engineering Tranny Mounts///UF Motorsports IATS
///Koni front + rear
WylM5 is offline
Old 14th April 2005, 10:20   #3
AndyE
Garage: Derv Burner
Send a message via MSN to AndyE
I wonder if this is a characteristic of the gearbox running with some new components, and some old components, a bit like replacing the chain on your bicycle, and not replacing the sprockets, the parts don't quite fit together.
Perhaps it will 'wear' in? Good luck.
AndyE is offline
Old 15th April 2005, 23:40   #4
Nuno Miguel
today i discoverd that my mecanic put almoust 2 lts of oil on gbox... shouldnt it be 1.25lts?
Old 16th April 2005, 01:57   #5
AndyE
Garage: Derv Burner
According to the specs in TIS, it should be 1.25L - but filling to the top of the filler hole (which is what you're supposed to do) takes 1.9L on my car. That's what I've used, filled it like that twice, and no problems.
AndyE is offline
Old 16th April 2005, 09:57   #6
yewcorner
yewcorner's Avatar
Garage: E60 M5 Interlagos Blue
I recently had Amsoil ATF put in my gearbox at the Inspection 11. It took nearly exactly 1.25ltrs, I have the other .75 in the garage. The mechanic said it was just starting to dribble out the filler hole. This is with the 5 speed box.
2005 E60 M5 Interlagos blue
yewcorner is offline
Old 17th April 2005, 23:51   #7
Nuno Miguel
Today 3rd gear clashed 2 times at high revs...
Old 17th April 2005, 23:54   #8
Nuno Miguel
Realy dont know if i love or hate my M5...
Old 18th April 2005, 14:06   #9
Nuno Miguel
Ummmm... tried shifting 3th today in various situacions and looks ok after all...
I think i better save money for a new gearbox.
Old 28th June 2005, 19:48   #10
illjah
Garage: 1995 M5 LE40/50 Orinico Green
All of this sounds VERY familiar.....
illjah is offline
Press Release no 3: The Seven-Speed SMG Gearbox Gustav E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 0 15th December 2004 01:18
Press Release 3: The new sequential M transmission: Shifting gears even faster wit... Gustav E60 M5 and E61 M5 Touring Discussion 1 5th July 2004 04:58
Press Release 3: The new sequential M transmission: Shifting gears even faster wit... Gustav Most Memorable Threads' 0 4th July 2004 22:28
SMG Press Release Omar E39 M5 and E52 Z8 Discussion 12 18th February 2001 23:45
Page generated in 0.17571 seconds with 11 queries
