Old 2nd April 2005, 23:22   #1
Smokestack
Smokestack's Avatar
Garage: 6 sp M5 Touring Stirling Silver
Time to let my M5 Touring go?????
I've got a tough decision to make .......
This is my third E34 M5. They've all been great cars. Costly but great. But, they feel their age, don't you think? You can't show a clean pair of heels to 99% of other cars on the road like you could when the car was current.
And, this is the big 'and', I need new EDC dampers all round. Is it worth £2500 to keep this car going. It still brings a smile to my face ... the 4 car overtaking manoeuvers on the A road going to work in the morning ... the mechanical whir of the straight six when it's on cam ...... the fact that an E39 M5 can't lose me in the wet no matter how hard it tries.
And its running up 190k kms now. There's the rattles and squeaks which drive me mad. The auto air con is noisey and takes half an hour to heat up the car in the winter. The appalling steering box contraption which makes the car feel so woolley in a straight line (but it always did didn't it ... why couldn't they have put rack and pinion in the car?).
But, I've just put new rear rubber on. I was running slicks and never knew. And, the car pulls oh so sweetly again. The engine's still so strong and tight.
But, I need dampers. I've forgotten what a good M5 feels like. Was it as good as I remember? The decay had been so gradual that I've forgotten what one feels like when its on song, being able to throw it around with abandon.
What should I do? Is it worth it? I need help!
I need reasons to spend this money!
Smokestack is offline
Old 3rd April 2005, 00:04   #2
Simonal
Simonal's Avatar
Garage: Alpina B10 V8s Touring
Re: Time to let my M5 Touring go?????
Well I may be a little biased as I purchased a Touring in Sep 04 and I think the cars are great.
I also need to replace the dampers at one point as well as the brakes but then that is the price that I am prepared to pay for a discret supercar - estate.
The ventalation problem could be down to the "famous microfilter" issue which I got to change late last year over the Christmas break. Since then the ventlation in the car has been great, also the speed with which the car heats up is almost instant also the noisy climate is probably due to the fan pulling through a blocked microfilter as I and others have had the same thing - now with a new filter most of the time I only use the lowest or no fan to ventilate the car.
For the squeaks and rattles even newer cars have these a guy I know with an RS4 has squeaks and rattles and that is a car about 5 -7 years younger than our cars.
As for the speed there may be another issues which is beyond my knowledge but I would get it checked out by a specialist, not a "stealership" as there are a number of very good one's out there......
Good luck with your decision.....also one other question what would replace it with ....RS4 - fast but too bland, RS6 - Better but expensive (and if you think the BMW is expensive just try an Audi!) E55 estate .... old mans car IMHO auto only (new version around £60,000+).
Have fun
Simon
Simonal is offline
Old 3rd April 2005, 15:18   #3
Smokestack
Smokestack's Avatar
Thanks Simon!
I'm feeling slighly better. You're right, of course. What do I replace it with?
Anyone else out there with reasons to keep this car?
Old 3rd April 2005, 20:31   #4
farrell
farrell's Avatar
Sales Feedback: (4)
Thanks Simon!
If the car is generally good & not requiring other suspension & bodywork then dump the EDC in its entirety & fit a conventional aftermarket performance suspension kit like Hartge, Dinan & Eibach have made or currently make.
Kurt Ramsden & many others have trod this path & it appears to be a smart move.
The car will have generally firm damper rates but you will half your costs including fitting & that is just compared to the parts cost of EDC. Add labour to fit & it is a no brainer.
I would have gone this route if I had more than one damper fail at any time.
Unfortunately, it has always been one at a time..
Good luck
Farrell
farrell is offline
Old 3rd April 2005, 22:48   #5
yewcorner
yewcorner's Avatar
Garage: E60 M5 Interlagos Blue
Don't forget Garcia has a fix for the rears and is working on the fronts;
Info at url: BMW memo regarding "seeping" EDC dampers?
I'd personally stick with the original EDC setup, it really is a superb suspension set up.
Good luck
Farrell
2005 E60 M5 Interlagos blue
yewcorner is offline
Old 3rd April 2005, 23:06   #6
Simonal
Simonal's Avatar
I think my choice is for the original dampers but I think it is very much personal choice Kurt, another board member, and although I have not driven the car by all accounts it is very good on the "fixed" suspension.
For my choice I will stick with the standard EDC but I think it is only about choice there is no wrong way or right way...IMHO
Simon
Simonal is offline
Old 4th April 2005, 22:08   #7
DrSakke
DrSakke's Avatar
Hi!!!
How about having a totally unique car which is hand-built in only 891 examples. (and it still DOES blow away a lot of the cars on the road, just not with completely the same confidence as in 92-95).
Cheers
Sakke
(A fellow touring owner)
DrSakke is offline
Old 4th April 2005, 22:47   #8
Smokestack
Smokestack's Avatar
This is helping ... oh yes! I'm nearly there. I might just order up some new front dampers at Munich Legends and see how it goes. The car is getting dangerous now.
See if we can't just conjure up some of that old majic!!!!!
Old 5th April 2005, 09:09   #9
farrell
farrell's Avatar
Sales Feedback: (4)
Smokestack
By all means let ML order them, but you will pay full retail plus vat...!
You can get better prices from a BMW dealer than ML.
As for fitting, ML has lower labour rates but it seems to take them longer to do things & then its wrong or something else gets damaged in the process.
I am not a fan, I am not impartial.... But I have been at the receiving end of their antics.
Keep the Touring but consider steering clear of ML.
Regards
Farrell
farrell is offline
Old 5th April 2005, 09:43   #10
yewcorner
yewcorner's Avatar
I can get the front dampers for £399 + VAT from William Jacks BMW (Sunningdale) ask for Steve Edwards tel: 01344 630420 and mention me, Brian, fellow E34 M5 enthusiasts.
Smokestack
Regards
Farrell
2 weeks old: My impressions of the SL 55 vs. M5 (very long) Rezf E39 M5 and E52 Z8 Discussion 34 30th September 2006 02:30
IMPORTANT FOR E34 M5 OWNERS! Old M5 Messageboard Archive. Help Needed! Gustav E34 M5 Discussion 6 25th February 2006 17:28
BMW M Manager Bruhnke at Stockholm Open, Sweden and answer to your questions Gustav E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 51 25th March 2005 18:14
New M5 information direct from Mr. Donnie Isley of the BMW Performance Center atomic80 E60 M5 and E61 M5 Touring Discussion 1 15th September 2004 10:45
Page generated in 0.22093 seconds with 11 queries
