Re: Airbag steering wheel connector
Originally Posted by Haim Toeg
I am trying to replace the steering wheel in my US 3.6 91 from the 4 spoke to a three spoke. Apparently the airbag on the three spoke has 5 cable connector as opposed to the 2 cable connector in the original wheel.
Anybody know whether these wheels can be interchanged and what cables should be connected where?
If you are trying to install the Z3 3 spoke wheel, the 5 wires are for the 2 stages of the airbag and the horn circuit - 4 wires for the airbag(2 spiral wound wires for stage 1 and 2 spiral wound wires for stage 2 - usually yellow) and 1 wire for the horn. If you want the airbag to be functional, you are only going to be able to connect 1 stage of the airbag since that is what the original E34 airbag was - a single stage airbag. Hope this helps.
so many mods......so little time.......
'93 E34 M5 - Mauritius Blue/Dove Grey - 3.8 cam gears, Conforti chip, SLS-delete Ground Control/Koni suspension, Alpina Softline 18's, Rogue Engineering short shifter, Eisenmann Race exhaust
'93 E34 M5 - Avus Blue/Dove Grey - 18" M-Parallels
SOLD & Sorely missed: '02 E39 M5 - Carbon Black/Caramel - Rogue short shifter, Rogue Power Pullies, opened brake ducts, ellipsoid fogs, slide/tilt armrest
