Old 28th March 2005, 20:37   #1
Cyrus
Garage: BMW E34 M5 3.8 Avus Blue
Resonator Flap Fixed!
Yes I made it work today.
I took evetrything apart for the second time and had a closer look. All of the motors worked ok, everything was fine except the hose that comes from the front of the engine whcih is atached to the non return valve. It had melted.
Replaced it with what I had.
I thought the flap was meant to self test with the car off but it doesnt! It only self tests on start up. I was mesingh about for ages thinking why doesnt it work on ignition 2!!
IN the end I gave up and just started the car and to my amazement it worked!
Driving is much smoother now and there is a noticeable difference in torque and over 6000rpm it really pulls hard.
Took me a while but I got there!
Thanks for all the help you guys gave me.
Cyrus is offline
Old 1st April 2005, 10:26   #2
yewcorner
yewcorner's Avatar
Garage: E60 M5 Interlagos Blue
Re: Resonator Flap Fixed!
Hi Cyrus
Good to hear you were able to fix your problem.
You replaced the hose to the front of the engine?
I changed all my hoses except this one? Where does it go to? It seems to go down underneath the front of the exhaust side of the engine? What does it plug into?
Brian
2005 E60 M5 Interlagos blue
yewcorner is offline
Old 1st April 2005, 15:00   #3
Cyrus
That front hose does not go to the exhaust side. It seems that way I know but thats actually another hose which comes from somewhere else.
This hose goes to the front of the engine just next to the water pump. If you look carefully and trace the hose you'll understand.
It goes to a non return valve and is very hard to change unless you take the radiator out.
If you flap is working then I wouldnt worry about it especially since youve change everything else. Taking everything off again just to change that hose when its probably ok not worth the effort.
Cyrus is offline
Old 1st April 2005, 19:07   #4
unesential
Garage: 1991 M5 black
Send a message via AIM to unesential
congrats and good work.
unesential is offline
What do owners like the least about their M5's? WIRELESS E39 M5 and E52 Z8 Discussion 43 31st January 2003 16:43
My car is all fixed up Ghost E34 M5 Discussion 10 19th July 2002 00:32
What items/changes would you make to a M5 to make it better? Apples E39 M5 and E52 Z8 Discussion 27 23rd October 2001 08:46
I LOVE MY M5, but..................... PaulMarin E39 M5 and E52 Z8 Discussion 14 11th September 2001 00:38
yee-haw! seat squeaking fixed. Jacob Lee E39 M5 and E52 Z8 Discussion 5 5th April 2001 06:18
Page generated in 0.12336 seconds with 11 queries
