Hot / Cold Air Control on Centre Console Vents - BMW M5 Forum and M6 Forums
Old 28th February 2005, 08:33   #1
phil.cavanagh
Garage: 1990 M5
Been having this 'feature' for a while now :
Intermittent problem getting hot air out of any vent other than the ones at the bottom of the windscreen, which can be affected by using the 'control wheel' located between the two air vents above the radio on the centre console.
Problem is I can't find a consistent mode of operation. eg. Cold air from centre vents, so move the 'wheel' up to the 'Hot' position, nothing...., back down to the 'Cold' position, and hey presto, red-hot air. The next time I try this, it may or may not work, or it produces hot air in the 'Hot' position. This morning, no hot air in any position (apart from windscreen vents).
Obviously this 'wheel' is controlling some sort of flap / valve arrangement to divert air into the heater matrix, but does anyone know the detail of what it is doing / or what is likely to be the problem..? The behaviour changes only after turning the ignition off, and back on again - so something electrical involved as well...?
(Changed the Microfilter a couple of weeks ago BTW, so lots of air 'volume' coming out of the vents, just not a consistent temp...)
Phil.
phil.cavanagh is offline   Reply With Quote
Dinan Cold Air Intake and those who have it.. MarkM5Lauderdale E39 M5 and E52 Z8 Discussion 25 29th May 2002 14:03
cold air intake? jinferno E39 M5 and E52 Z8 Discussion 9 1st September 2001 10:46
Anyone have DINAN cold air? E39 M5 and E52 Z8 Discussion 2 16th February 2001 04:39
Revisit: Dinan Cold Air Intake AlbertM E39 M5 and E52 Z8 Discussion 4 6th December 2000 02:57
Cold Air Intake Nico E39 M5 and E52 Z8 Discussion 2 25th November 2000 01:03
