Old 25th September 2004, 04:31   #1
icM5er
Garage: ///M5 Black
Loss of power during full acceleration, help appreciated
Well this year I finally decided to enjoy my 91 M5 with 52k miles. For the past 3 years of ownership, it has been a garage queen, pampered. Lately, I have been driving it often, putting anywhere from 100-150 miles each time I take it to work. It has been running flawlessly, as would be expected from a car with only 52k miles and extremely clean.
Today however, I noticed that under full throttle, in third gear, at around 5500rpm it lost power, like when you drive a car that is very low on gas and it is ready to quit.
Over the next 10 miles or so, I tried a few more times to duplicate the problem and sure enough, only under full throttle, accelerator fully depressed, at 5500rpm it would loose power, in second, third or fourth gear. Other than 5500 rpm, the car pulls strong like usual, throughout the rest of the rev range.
Three hours later on my way home, I tested it again and only under full throttle, it lost power but it seemed more pronounced. Over the next twenty miles or so I tried gradual acceleration and the car runs fine, from stand-still to 6500.
So my problem appears to occur only under full throttle at 5500rpm, other than that, the car runs strong and seems fine.
What could be the problem?? The car needs nothing, all maintenance is current, fuel tank is full, gas is 93 octane.
Thanks in advance.
icM5er is offline
Old 25th September 2004, 04:49   #2
BreakerBacker
BreakerBacker's Avatar
Garage: 1995 M5 Touring, Orinoco Met.
Re: Loss of power during full acceleration, help appreciated
I dont know these cars as well as most on this board, but it kind of sounds like a fuel pump on the brink of failure. Good luck on solving the problem. I bet you cant wait to have it back performing 100% for those nice long rides to and from work.
BreakerBacker is offline
Old 25th September 2004, 05:21   #3
JohnR
JohnR's Avatar
Garage: 1993 M5 3.8 Black
Thanks in advance.
Mine had the same problem (a 93 ). I replace the Bodwen cable (throttle) and it fixed the problem. Hope this helps!!
JohnR
JohnR is offline
Misfire under full acceleration and SES warning? jds E39 M5 and E52 Z8 Discussion 48 11th April 2007 14:20
Removed K&N Filters--Car now hesitates upon full acceleration steveB E39 M5 and E52 Z8 Discussion 7 16th October 2001 05:15
Engine cutting off under full acceleration fabmaster E34 M5 Discussion 3 4th September 2001 15:02
Need advice on Dinan Differential ? Fury E39 M5 and E52 Z8 Discussion 61 23rd June 2001 09:01
How long before full power? greg E39 M5 and E52 Z8 Discussion 6 24th July 2000 17:19
Page generated in 0.11003 seconds with 11 queries
