Re: Changing Brake Hose Questions
The way i have done it on other cars is take each hose off one at a time. This you won't completley drain your master cylinder. You should check it periodically though and fill it as needed buring the install. It also might help if your line fittings are corroded to heat them up slightly with a torch in order to have the fittings expand so the chances are slim that you'll strip the threading.
Hope this helps!
John Wood
1988 BMW M5 (13k)
1995 Ford Taurus SHO (117k)
