Old 5th August 2004, 22:31   #1
Mmm-Five
Air 'Con'
Just got the bill for my air con service...£576.30
The initial check cost £66.67
Diagnosis was a seized motor/fan/ventilator.......
Air con ventilator (fan) £231.49
Replace air con fan £40.00
Discharge and recharge £93.33
Air con gas £35.00
Air con dye £11.99
Air con oil £11.99
Total of £490.47, plus vat
At least I get a free air con leak check in a fortnight and now have icicles on the end of my glasses
2006 e86 Z4MC (überkart)
http://mmm-five.net/
Mmm-Five is offline
Old 5th August 2004, 23:05   #2
plisken
plisken's Avatar
Garage: 95 BMW M5 green, 3.8 6spd
Re: Air 'Con'
Air con gas £35.00
Air con dye £11.99
Air con oil £11.99
Show off
Mine's working, but it certainly aint that cold
Just out of curiosity, what sort of delay is there between cycles, ie when the revs jump up a little?
Mine seems to come on every 15 seconds or so and stay on for as little as 5 seconds at a time, I have no idea if this is normal or not...
95 E34 3.8 M5 6spd
87 Capri280 Turbo Technics, +290bhp@17psi [Not Currently For Sale]
83 Capri 2.8injection RIP
93 Mitsubishi Pajero
plisken is offline
Old 5th August 2004, 23:21   #3
Mmm-Five
Re: Air 'Con'
Originally Posted by plisken
Show off
Mine only jumps by about 200rpm when I'm at idle - otherwise there is no noticeable jump.
I doesn't 'cycle' as you put it, it just goes to 1000rpm and stays there!
Mmm-Five is offline
Old 6th August 2004, 01:40   #4
plisken
plisken's Avatar
Re: Air 'Con'
yea, it rises to about 1000rpm or so, and is only really noticable at idle, though it can be felt while in slow/town traffic.
I thought that when the A/C was running, it would cycle, ie. come on and off, which was noticable by the rise and fall of the revs.
Thats what my BMW mechanic said anyway
95 E34 3.8 M5 6spd
plisken is offline
Old 6th August 2004, 10:18   #5
Mmm-Five
Re: Air 'Con'
That sounds more like a description of climate control which keeps the inside temp to a set level depending on what you set on the controls (by switching on and off?), the air con just blows as hot or cold all the time.
Mmm-Five is offline
Old 6th August 2004, 11:06   #6
phil.cavanagh
Garage: 1990 M5
Re: Air 'Con'
Air con gas £35.00
Air con dye £11.99
Air con oil £11.99
Was this the aux fan at the front of the engine bay that pushes air through the A/C condensor...?
I had _exactly_ the same work done two weeks ago, and it sounds to me like your garage was taking the piss....
Initial Check £Free
Fan £150
Labout to fit £42.56
Discharge & Recharge (including Gas, UV Dye, Oil + inspection) £45
Total £237.56 + VAT
Phil.
phil.cavanagh is offline
Old 6th August 2004, 13:39   #7
plisken
plisken's Avatar
Re: Air 'Con'
It is the "Automatic" A/C that my car has...
95 E34 3.8 M5 6spd
plisken is offline
Old 6th August 2004, 17:33   #8
Mmm-Five
Re: Air 'Con'
Initial Check £Free
Fan £150
Total £237.56 + VAT
Item 3 on this page http://rust.mine.nu/bmw/showparts.do...55&x=113&y=139 (part # 64541392913)
Mmm-Five is offline
Old 6th August 2004, 17:34   #9
Mmm-Five
Re: Air 'Con'
That's probably why your's keeps cycling then - mine's manual!
Mmm-Five is offline
Old 6th August 2004, 18:19   #10
phil.cavanagh
Garage: 1990 M5
Re: Air 'Con'
Yep.., thats the aux fan. Europarts supply this part for £150 + VAT, so I'm assuming you had this work done at a BMW dealer ?
Parts are one thing, but charging £218.98 + VAT for an A/C check and regas is _realy_ taking the piss. 1 Hour labour (max) + less than £2 in consumables (1200g gas, oil & dye) IMHO... My local A/C specialist do this for £45 + VAT.
Phil.
Days 3 and 4 - Final Heat Tests, Conclusions and Recommendations greg E39 M5 and E52 Z8 Discussion 51 28th June 2007 23:06
Long and technical: thoughts on cold air intakes and temp sensor relocation greg E39 M5 and E52 Z8 Discussion 48 4th August 2006 10:23
Hot weather, Air con? plisken E34 M5 Discussion 13 28th April 2004 11:00
Some air filter info from BMWE34.net BKH E39 M5 and E52 Z8 Discussion 1 30th October 2003 20:39
Air Con Clutch fell off! DaveW ALPINABoard.com | BMW Alpina Discussion 6 7th August 2002 13:02
Page generated in 0.15521 seconds with 11 queries
