Originally Posted by phil.cavanagh
Where is it !, and how much of a pain is it to change the thermostat.
BTW : 1990 3.6 M5
Thanks....
It's located on the right-side in front of the engine. You need to remove the windscreen-fluid reservoir(s) to reach it. The thermotat housing is bolted with 5 10mm hex bolts.
All in all, replacing the thermostat is not that difficult, but ou'll need 2 to 3 hours, depending on your skills.
1: Drain the coolant by opening the plastic screw that is located on the bottom (left) side of the radoator.
2: Remove the windscreen-fluid reservoir(s).
3: Unscrew the 5 10mm bolts of the thermostat housing. Release the three hoses that are attached to it and remove the housing.
4: Remove the old thermostat (Remember it's orientation. The new one must be mounted in the same direction.
5: Pry out the old metal O-ring in the thermostat housing. This is the most difficult part as you need to cut it out.
6: Press the new O-ring into the thermostat housing.
7: Install the new thermostat into the thermostat house. Watch the orientation!!!
8: Reinstall the thermostat-housing, fasten the 5 10mm bolts and reinstall the other removed parts.
9: Replace each and every coolant hose in the engine bay (Recommended but not required)
10: Close the plastic screw of the radiator.
11: Fill the coolant system with 13.5liters of nitrate free coolant untill the max mark.
12: Open the bleed screw near te plus terminal
12: Place the heater system on max temperature and set the fan to full speed.
13: start the engine.
14: Continue to fill coolant untill the level stays constant at the max mark.
15: Close the bleeding screw when there is a constant overflow of coolant (i.e. no air left inside)
16: Ready.
