Old 3rd August 2004, 22:10   #1
M5 powered
Garage: M5 limited edition (02/50) Rosso Red
1995 brakes ooooh
Just had the brakes completely overhauled. The bill was astronomical
and comprised of new discs, pads all round, handbrake shoes, stainless brake lines, dot 5 racing fluid...etc... etc..
However even though the best part of a £1K has gone, the brakes are now Godlike. I didn't realise there could be such a difference. They are frighteningly good.
The only thing you do have to be careful of is to get the front disks on the correct wheel as they are directional, epecially as they are counter-intuative. The inner vanes on the disc sweep back to the direction of travel rather than scoop air moving forwards. I guess air is pulled into the centre of the hub and spun out.
Best
M5 Powered
1995 M5 Limited Edition (02/50)Rosso Red
Pilot Sport 2 Rubber
Valentine One With Conceal
Twin Head LRC100 IR Jammer System
Origin Blue B2 GPS
M5 powered is offline
Old 3rd August 2004, 23:57   #2
plisken
plisken's Avatar
Garage: 95 BMW M5 green, 3.8 6spd
Re: 1995 brakes ooooh
Best
M5 Powered
Nice one mate...
I'm planning on doing something similar in a few months, think I was quoted £760 for the lot though from my dealer, will have to check but that may not have included the brake lines.
Godlike, I like it...
95 E34 3.8 M5 6spd
87 Capri280 Turbo Technics, +290bhp@17psi [Not Currently For Sale]
83 Capri 2.8injection RIP
93 Mitsubishi Pajero
plisken is offline
Old 4th August 2004, 00:19   #3
kevinpayneuk
kevinpayneuk's Avatar
Garage: E34 M5 Cosmos Black
When I had new front discs the dealer put them on the wrong way round. Some 5k miles later, during a routine check just be the Alps meet last year, they spotted the mistake so swapped them back. They kindly told me and all seemed ok until I needed to brake from 80+ mph as between 80 & 60 the shuddering was dreadful. Anyway, they fitted new ones FOC and once again all was well.
They really do work very well bringing quite a heavy car to a stop in very short order and very fade free.
Kevin
'89 E30 M3 Cecotto - Macao Blue
'95 E34 M5 3.8 6spd, MParallels etc - Cosmos Black
'98 E39 528i Touring Auto - Calypso Red
'04 E46 330Ci Convertible - Titan Silver
kevinpayneuk is offline
Old 5th August 2004, 01:07   #4
Brian M5
Brian M5's Avatar
Garage: 1995 E34 M5 LE Rosso Red
Guys,
So if the discs are directional, which one is which.
I've been having a lot of vibration from the brakes which is getting progressively worse despite the discs being replaced last Inspection II. I am also wearing the inside edge off the front tyres so the car is booked in for a check up tomorrow.
I had a quick look at the discs and have ******5 on the nearside and ******6 on the offside.
E34 M5 UK LE Rosso Red / Champagne.
Brian M5 is offline
Old 5th August 2004, 01:19   #5
kevinpayneuk
I don't know sorry, the dealer did all the work.
I can have a look in the morning if that helps? Roughly where on the disc are the numbers & can they be seen without removing the wheels?
Kevin
Old 5th August 2004, 01:39   #6
Brian M5
Brian M5's Avatar
Kev,
The numbers can be read through the gaps in the alloys. The Part No.s are stamped in adjacent to the M\\\ and were easy to read.
Thanks,
Brian M5 is offline
Old 5th August 2004, 01:42   #7
dronfieldm
Garage: 1995 BMW M5 3.8 6 Speed - Avus Blue
I'm sure I've just read a post stating that the blades of the vents should point forward not backwards ?
This help ?, or can anyone confirm whats correct.
I'd check, but after a bottle of cider don't want to move the Range Rover from my garage door !!!!
MJD
1995 3.8 6 speed - gone, but not forgotten.
1999 Land Rover Discovery Td5 ES
dronfieldm is offline
Old 5th August 2004, 01:57   #8
M5 powered
MJD
WRONG.....THE BLADES SHOULD POINT BACKWARDS (SWEPT BACK). On each hub there is actually an L and R after the part number for left and right.
Origin Blue B2 GPS
Old 5th August 2004, 02:08   #9
Brian M5
Brian M5's Avatar
A good late night flurry of activity here.
Thanks M5 powered
I just had to go out and fiddle about in the garage with a torch (flashlight) and I am fitted up correctly.
Didn't see the L and R designations first time round cos of the big gap from the serial No.
So my vibes are caused by something else. Too much late braking maybe.
Brian M5 is offline
Old 5th August 2004, 09:44   #10
dronfieldm
Sorry guys. It was the first post on this thread that I'd read a day or so ago.
"The inner vanes on the disc sweep back to the direction of travel rather than scoop air moving forwards."
It was obviously late when I posted - hence the memory overload !!
Mark
dealer already claiming he's charging over sticker Tomk E60 M5 and E61 M5 Touring Discussion 48 2nd August 2004 16:32
Brake Rotor Issue Joe Lapicki E39 M5 and E52 Z8 Discussion 29 26th December 2002 16:42
Funny story about the 1995 M5 floating caliper brakes. Gustav E34 M5 Discussion 4 24th December 2002 06:30
Next project! - New brakes but have some questions atomic80 E39 M5 and E52 Z8 Discussion 9 16th April 2002 23:29
Page generated in 0.14885 seconds with 11 queries
