Old 3rd August 2004, 14:14   #1
Nuno Miguel
Garage: Bmw e34 3.6 M5 Red
Best oil for 88.000 miles 3.6 M5?
hi, what is the best oil for my car, a 91 3.6 M5 with 88.000 miles/140.000 km???
Nuno Miguel is offline
Old 3rd August 2004, 20:06   #2
Donati
Garage: 2 x '91 M5, Sebring Grey
Send a message via ICQ to Donati
Re: Best oil for 88.000 miles 3.6 M5?
There are several options that are ok.
However, it seems that most of us are using Castrol TWS.
Mvh. Finn Donati
Donati is offline
Old 3rd August 2004, 20:28   #3
Ghost
Ghost's Avatar
Garage: Carbon Black E39 M5
Castrol TWS is good but I had a hard time finding it once so I used Shell Racing 10W60, seems like a good oil.
Ghost is offline
Old 3rd August 2004, 20:52   #4
Donati
I think all the BMW dealers have the TWS oil, because this is what they are supposed to put in the E39 M5's.
But the price from the BMW dealer is just too silly
Mvh. Finn Donati
Donati is offline
Old 3rd August 2004, 21:56   #5
M5 powered
Garage: M5 limited edition (02/50) Rosso Red
I'd go for Mobil One 15/50 Watt (the new formula is slightly thicker even though its fully synthetic) or Castrol Magnatec 10/40 Watt which I believe is semi-synthetic. Don't use anything less that 10 otherwise you'll develop leaks and the engine's timming chain tensioner won't work efficiently.
The only difference you may find is that the full synthetic oils cause the engine to be more rattley on start-up.
best
M5 Powered
1995 M5 Limited Edition (02/50)Rosso Red
Pilot Sport 2 Rubber
Valentine One With Conceal
Twin Head LRC100 IR Jammer System
Origin Blue B2 GPS
M5 powered is offline
Old 4th August 2004, 01:10   #6
Nuno Miguel
best
M5 Powered
i am from portugal, here is normal to have temperature of 30/40ºc anda not less then 0 ºc.
dont you think 2ow-50 would be better?
Old 5th August 2004, 01:24   #7
dronfieldm
Garage: 1995 BMW M5 3.8 6 Speed - Avus Blue
I just stick with what the manual says, 15w 40 or 15w 50.
It's written in black and white. I'm not having a go, - far from it, but it says it in the book. I am not meaning you can't read, please don't take this the wrong way, but if thats whats recommended, thats what I put in. .
So I use Castrol Magnatec 15w 40............well happy.
Does the temperature where you live make that much of a difference ? I'm not sure................maybe others know better ?
Mark
1995 3.8 6 speed - gone, but not forgotten.
1999 Land Rover Discovery Td5 ES
dronfieldm is offline
Old 5th August 2004, 02:02   #8
M5 powered
Mark
If you live in a hot country or go to the track lots then 15/50 or 10/60
Otherwise if you live in blightly...and behave
10/40 is fine and yes go with Castrol Magnatec.
Origin Blue B2 GPS
Old 5th August 2004, 23:24   #9
Nuno Miguel
My trusty mecanic said that 5w40 would be ok, but if it was is car hed use castrol 10w60, but that is a racing oil? right? it must be very expensive...
P.s: my local bmw dealer put in the last service... 0w30 castrol... just has i suspected, not suitable...
Old 6th August 2004, 11:41   #10
M5 powered
5 / 40W is still too thin. 10/60W would be fine but personally I'd go for a 15 owing to the age of the engine. This way you minimise oil leaks too!
Origin Blue B2 GPS
2 weeks old: My impressions of the SL 55 vs. M5 (very long) Rezf E39 M5 and E52 Z8 Discussion 34 30th September 2006 02:30
What engine oil do you use in your E34 M5? bandit E34 M5 Discussion 31 7th December 2002 09:40
Your thoughts on the Z8 NO-MERCY E39 M5 and E52 Z8 Discussion 6 16th November 2001 06:26
Page generated in 0.16036 seconds with 11 queries
