Old 2nd August 2004, 16:12   #1
plisken
plisken's Avatar
Garage: 95 BMW M5 green, 3.8 6spd
Auxiliary fan
I notice the auxiliary fan at the front of the radiator come on and off when the A/C is on, but I have still never seen it come on when the car is running without the A/C.
As I understand it there, are two relays, for 2 speed operation, how can I test the operation of my fan?
Where is the temp' sensor?
Just me looking for problems again
95 E34 3.8 M5 6spd
87 Capri280 Turbo Technics, +290bhp@17psi [Not Currently For Sale]
83 Capri 2.8injection RIP
93 Mitsubishi Pajero
plisken is offline
Old 2nd August 2004, 21:05   #2
e34m5uk
Garage: Sterling Silver 1993 3.8
Re: Auxiliary fan
There should be a temperature switch on the top right (or could be left) corner of the radiator with 3 wires coming out of it, if you short the brown and either of the other 2 wires the fan will run at low speed or high speed. The relays for the aux fan are in the auxiliary relay box in the engine compartment. In normal operation the fan will only run in high speed mode when the car starts to overheat.
Miles
e34m5uk is offline
Old 9th September 2004, 05:32   #3
prairieman
Garage: Black E34 M5
Re: Auxiliary fan
if I may intrude on your auxiliary fan thread...
I'm working through a laundry list of minor issues on my car. After reading this post, I decided to dig nto my aux fan problem.
The auxiliary fan runs continuously on my M5, I suspect it is high speed, but it could be low.
I disconnected the coolant temp switch with no change. I can stop it by pulling either fuse 25 or fuse 29.
I've only owned the car for a week and haven't purchased a proper manual yet (but I will) I've been digging through several BMW forums, searching on "aux fan". Most threads deal with a fan that will not operate - mine won't shut off LOL
Are there common causes I should pursue first ?
thanks.
Brad
1979 633CSi
1981 745i
1991 M5
1992 735i
prairieman is offline
Old 9th September 2004, 08:12   #4
plisken
plisken's Avatar
Re: Auxiliary fan
thanks.
Brad
1979 633CSi
1981 745i
1991 M5
1992 735i
There is a small relay box under the bonnet LHS, just in front of the fuse box, I think it is called the Auxiliary Power box or somehting like that.
Inside you will find 3 relays, possibly more, but on my car there are 3, 1 large which controlls the headlight washers, and 2 others which control both the slow and high speed for the auxiliary fan.
It is possible that one of them is jammed on...
I have not looked further into my auxiliary fan, in that I know it comes on with my A/C but have yet to see it coming in when stuck in trafic etc.
95 E34 3.8 M5 6spd
plisken is offline
Old 9th September 2004, 12:46   #5
Tubbs
Tubbs's Avatar
Garage: E34 M5 1993 3.8 Oxford Green
Re: Auxiliary fan
Not wishing to worry you or anything but if your aux fan is jammed on you probably want to get it sorted pretty sharpish. I've just checked a recent invoice from when my aux fan seized + a/c stopped working. Cost of the aux fan alone is £208.34 + VAT + fitting!
ex-M5 Owner
eBay Auction:
http://cgi.ebay.co.uk/ws/eBayISAPI.d...tem=4559573500
Tubbs is offline
Old 11th September 2004, 04:10   #6
prairieman
Re: Auxiliary fan
It would appear that I gonna need a wiring diagram.
I pulled the high speed relay and replaced it - no change. For whatever reason, there is power to the relay whenever the key is turned on.
Brad
1979 635CSi
1981 745i
1991 M5
1992 735i
Old 11th September 2004, 11:32   #7
plisken
plisken's Avatar
Re: Auxiliary fan
Brad
1979 635CSi
1981 745i
1991 M5
1992 735i
There must be a temp' sensor somewhere, nor too sure if it is the one on the top right hand side of the relay (O/S) or not...
95 E34 3.8 M5 6spd
plisken is offline
Old 11th September 2004, 16:46   #8
e34m5uk
Re: Auxiliary fan
There are 2 things which will make the fan come on 1) The temperature switch on the radiator (with 3 wires coming out of it) 2) The pressure switch in the aircondtioning drier/receiver.
As you have already tried disconnecting the temperature switch I would suspect that the pressure switch is faulty ?
Miles
Brad
1979 635CSi
1981 745i
1991 M5
1992 735i
e34m5uk is offline
Old 11th September 2004, 17:52   #9
plisken
plisken's Avatar
Re: Auxiliary fan
Miles
A little OT, but where then would the temperature sender unit be, for the temperature gauge?
95 E34 3.8 M5 6spd
plisken is offline
Old 11th September 2004, 19:46   #10
e34m5uk
Re: Auxiliary fan
The temperature sender for the gauge is normally on the engine block somewhere, although not having an M5 anymore i couldn't say exactly where
Miles
e34m5uk is offline
Part number for engine fan & Fan shroud B3ND3R E34 M5 Discussion 9 28th November 2004 02:26
Wanted : Auxiliary fan for 1990 E34 M5 phil.cavanagh For Sale or Wanted 5 6th July 2004 10:15
Heater A/C - Fan Blower - Fuse???? sctazmon E39 M5 and E52 Z8 Discussion 1 27th June 2004 22:19
E 46 fan problem Jonas400 E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 1 10th October 2002 14:14
Auxiliary fan fuse location? Brent E39 M5 and E52 Z8 Discussion 2 10th July 2002 21:34
Page generated in 0.17191 seconds with 11 queries
