Old 26th July 2004, 11:23   #1
Husaborg
Garage: M5 Cosmos Black
Removing the cat
Does anyone know if i can remove the catalytic converter on my 1991 3.6 M5.
Just wondered if this is possible or whether there are any sensors that may need to be bypassed.
Any comments will be appreciated.
Husaborg is offline
Old 26th July 2004, 17:08   #2
Pepsmeister
Garage: 1995 BMW M5 Shadowline
Re: Removing the cat
HI,
There is a sensor before the cat, so you don´t have to worry about any ECU screw-ups if you remove it, which is not the case with the e39 M5...
If the sensor was after the cat, you´d have to install a small resistor in order to trick the ECU into thinking that it´s still there.
I took off my cats too, the car got a lot better IMHO, and the exhaust noise is even nicer.
1995 BMW M5 Schwarz II Shadowline
Dr. Schrick camshafts
UUC Short-shifter
Pepsmeister is offline
Old 26th July 2004, 19:19   #3
IvanDias
IvanDias's Avatar
UK note;
Any car sold new in the UK after 1st January 1990 was required to be fitted with catalytic converters. BMW started earlier, most mid 1989 cars onwards had them.
If you remove the cats, then theorectically the car is an MOT failure.
Therefore you will need to be on friendly terms with your testing station before doing it; Might be worth a word in their ear first to make sure that they won`t get funny about it.
Aggro to put them back on again just for the test!
Ivan.
IvanDias is offline
Old 26th July 2004, 20:30   #4
AndyE
Garage: Derv Burner
Send a message via MSN to AndyE
Ivan
Sorry, but that's wrong.
Passenger cars with engines fuelled by unleaded petrol and registered on- or after 1 August 1992 are subject to a more stringent emissions test during the MOT - one which is practically impossible to pass unless you have a catalyser.
So in essence, what you're saying is correct - but you got the date wrong.
AndyE is offline
Old 28th July 2004, 14:03   #5
Ghost
Ghost's Avatar
Garage: Carbon Black E39 M5
Has anyone done this, removed the cat? If so what did you replace it with, just a straight pipe or some mufflers? I've been thinking about removing it but don't really want it to get much louder.
Ghost is offline
Old 28th July 2004, 15:23   #6
ilundber
ilundber's Avatar
Garage: 1991 M5 Lagunengrunmetallic and 2001 M5 Le Mans Blue
Has anyone reflected over the environmental consequeses?
I understand that you might get a bit more power and sound, but you will increase pollution. Is it worth it?
ilundber is offline
Old 29th July 2004, 13:25   #7
IvanDias
IvanDias's Avatar
Originally Posted by AndyE
Ivan
Oops, my mistake.
I was getting mixed up, compounded by the fact that my 1989 535i has no cat and a larger filler neck, while the 1990 M5 has cats and a narrower filler neck that only accepts unleaded nozzles.
I stand corrected for the second time in two days, having raised the wrath of Mr Levinson in another thread. Gulp!
Note: Unleaded fuel nozzles in the UK will also fit diesel cars. Don`t ask how I know this. I`ve not tried it the other way round, but feel free...
Ivan.
IvanDias is offline
Old 29th July 2004, 13:45   #8
Mmm-Five
You 'might' increase pollution if you remove the cat, as all that pollution that the cat is 'saving' will eventually have to be released from the cat when it is 'recycled'!
Don't forget, cars contribute less than 5% to overall polution - industry produces over 80%.
2006 e86 Z4MC (überkart)
http://mmm-five.net/
Mmm-Five is offline
Old 29th July 2004, 16:41   #9
ilundber
ilundber's Avatar
No, that is a misconception. If the cat would be filled with the pollution, e.g. it stays in the cat, it would get clogged in no-time, or I would need a 30 cubic metres container pulled behind the car to store the pollution after having done 250.000 km with the car.
It creates a chemical reaction that reduces pollution. The metal in the cat is only there to create and maintain the chemical reacion. It does not "store" any pollution, nor does it get consumed by the reacition. It is there as a catalyst, hence the name
Check out this documnt and you'll see what I mean www.autoshop101.com/forms/h64.pdf
ilundber is offline
Old 29th July 2004, 20:44   #10
AndyE
Garage: Derv Burner
HAAAAAAAAAhahahaha
AndyE is offline
IMPORTANT FOR E34 M5 OWNERS! Old M5 Messageboard Archive. Help Needed! Gustav E34 M5 Discussion 6 25th February 2006 17:28
Adding a cat Asterix Off Topic Forum 0 27th May 2004 09:46
Cat on car! What to do? Suretyagent E39 M5 and E52 Z8 Discussion 51 12th April 2004 19:47
Opinions about removing the cat Pepsmeister E34 M5 Discussion 3 20th February 2003 01:07
car destroying cat led foot E39 M5 and E52 Z8 Discussion 6 25th June 2001 20:02
Page generated in 0.16103 seconds with 11 queries
