Old 23rd July 2004, 05:55   #1
rebel1
rebel1's Avatar
Garage: that way
Send a message via AIM to rebel1
Window operation problem HELP
My 95 seems to have developed a intermitent window problem. Sometimes some of them work, other times none of them work, with no apparent pattern. When i press the button I can hear the solonoid or what ever clicking. Does any one have an idea? The moonroof seems to work regardless.
Thanks guys;
Bruce
rebel1 is offline
Old 23rd July 2004, 06:49   #2
plisken
plisken's Avatar
Garage: 95 BMW M5 green, 3.8 6spd
Re: Window operation problem HELP
Thanks guys;
Bruce
Just when you mention this...
My back passenger window no longer works, but I can also hear some sort of solenoid action when either of the buttons are pressed.
I was going to replace the motor, but would hate to do that if it were something a little more trivial.
95 E34 3.8 M5 6spd
87 Capri280 Turbo Technics, +290bhp@17psi [Not Currently For Sale]
83 Capri 2.8injection RIP
93 Mitsubishi Pajero
plisken is offline
Old 23rd July 2004, 17:10   #3
bobz
bobz's Avatar
Garage: E34 M5 Black
Just a thought have you guys tried to lubricate the runners and the arms inside the door, as the way the car knows when the window is fully up or down is by the current drain through the motor and then switches off, but if the guides are sticking it will think the same and not work?
BobZ
bobz is offline
Old 23rd July 2004, 17:53   #4
M5 powered
Garage: M5 limited edition (02/50) Rosso Red
BobZ
Crickey, its catching my rear passenger one has stopped working too.
I can't imagine its a duff motor. They would have hardly ever been used!
I guess to test your theory bob, get someon to press 'down' while someone gently pushes the window down. It should thus move.
If you hear clicking it is definatly at the window / motor end. Not a fuse
1995 M5 Limited Edition (02/50)Rosso Red
Pilot Sport 2 Rubber
Valentine One With Conceal
Twin Head LRC100 IR Jammer System
Origin Blue B2 GPS
M5 powered is offline
4.6is problem Mori X5 and X6 Forum 5 2nd May 2005 16:11
Tint problem w/ dot-matrix rear window kevin034 Off Topic Forum 6 19th April 2003 18:56
Useless Factoid: one-touch window operation chunpng E39 M5 and E52 Z8 Discussion 14 20th August 2002 23:37
Reflecting Window + Radardetector= problem?!! MRacer E39 M5 and E52 Z8 Discussion 8 16th January 2002 10:23
Page generated in 0.22823 seconds with 11 queries
