Old 22nd July 2004, 00:02   #1
Prutser
Prutser's Avatar
Garage: Diamantschwarz-metallic 1992 BMW E34 M5 3.8
Send a message via ICQ to Prutser
Freakin' expensive manifold!
I took the 1992 3.8l to the garage for the annual car safety inspection (APK) today and to my surprise it failed the test! Apparently the flexible joint in the first exhaust manifold (cylinders 1-3) took so much wear and tear over the last 12 years that it started leaking. As a result, the lambda probe further down the exhaust registers a high oxigen level (as fresh air now enters the exhaust through the faulty manifold) and responds by making the fuel much richer. This results in unburned fuel, which apparently causes the carbon monoxide level of the exhaust gas to go skyhigh (and way over the level tolerated by law).
Now replacing the leaking manifold seems the only option, but this thing turns out to be 1500 euro for the 3.8l (1300 euro for the 3.6l models)! That is excluding labour for replacing it.
Am I out of luck and do I face spending around 2k (manifold + labour) for a three-cylinder manifold piece, or do I have more options? I haven't searched the auction sites yet, but 3.8l M5's are rare in the Netherlands, so unused, 2nd hand manifolds that are in good condition must be even worse. Where do I start?
P.S.
The part's serial number is 11.621317080
cheers,
Erik
1992 3.8 ///M5
Prutser is offline
Old 22nd July 2004, 00:37   #2
RandyZ
Garage: 1991 M5 Black
Re: Freakin' expensive manifold!
How about repairing it - Can you show it to a good welder. He should be able to advise you if a repair can be made.
RandyZ is offline
Old 22nd July 2004, 00:41   #3
Prutser
Prutser's Avatar
It turns out that has already been done in the past. My mechanic looked at it and says it probably can't be welded twice.. (although he's biased of course )
1992 3.8 ///M5
Prutser is offline
Old 22nd July 2004, 04:39   #4
mblaster
mblaster's Avatar
Garage: 91 m5 black
Get that part to a good welder, there isn't any rule that says a part can only be welded once.
91 E34M5 3.6 Dinan Stage 3, Konis, Dinan chip and cam gears, Kelleners strut bar,
Header back custom exhaust w/ Eisenmann Race 83mm, Staggered Polished T-Stars,
Passenger canyon puke bag.
mblaster is offline
Old 22nd July 2004, 06:53   #5
de Witt
de Witt's Avatar
Garage: 1988 M5 (x2) 1991 M5 2008 M5
Send a message via AIM to de Witt
Agreed. Your mechanic might be throwin some bs your way to get a nice expensive manifold in. Any welder who knows what he's doing wont hesitate to give it a try if they feel they can.
{o,o}
|)__)
The E28 M5 FAQ
The E34 M5 FAQ
The E24 M6/M635CSi FAQ
de Witt is offline
Old 22nd July 2004, 22:31   #6
Prutser
Prutser's Avatar
I made some phone calls today with BMW specialists and as usual: the more opinions you ask, the more different stories you hear. One was about the flexible joint. According to one specialist it has no purpose other them making it more helpful for mechanics to fit the part (so he can twist it into place more easily). His suggestion was to just take a thick pipe, cover the entire joint and weld everything together. All you loose is some flexibility when putting the manifold in place.
Now it could be just me, but I always thought the main purpose of the joint was to allow the differently sized manifolds (the first is a lot longer than the second) expand and shrink as they heat up and cool off. Removing the flexible joint would cause tension on both manifolds and the cylinder head.
It sure is hard to find the real specialist.. but I'm sure he's out there somewhere!
1992 3.8 ///M5
Prutser is offline
Old 1st December 2004, 00:03   #7
Cyrus
Garage: BMW E34 M5 3.8 Avus Blue
Hi,
Did you end up fixing this problem?
Cyrus is offline
Old 1st December 2004, 06:41   #8
Danish-M
Danish-M's Avatar
Garage: E60 M5 Alpine White, E34 M5 Touring Daytonaviolett
Originally Posted by Cyrus
Hi,
Yeah, please let us know what you ended up doing here.
I got the same diagnosis on my M5 touring a couple of months ago, and I am looking at replacing the manifold, unless you can give me some advise on how to get around this problem in a cheaper way.
PLEASE HELP.
Danish-M is offline
Old 1st December 2004, 09:34   #9
Cyrus
I think the only solution is welding.
The biggest problem is finding a decent welder who is going to take his time looking at the problem and then do a good job.
As time goes by Im finding that more and more garages just dont give a **** anymore and dont put the heart ito the work even though you are paying them good money.
I have actually had some success with an idea of mine. I just happened to accidently venture into halfords and came accross the exhaust repair section.
Theyve got this metal sheet which is just wider than the flexi joint. So what Ive done is wrap the sheet around the joint. It comes with an attached big jubilee clip. This seems to be working so far but how long it will last I dont know.
Also, i think the flexi joint is there just to make fiting purposes easier. Why does only one of the manifolds have it?
Cyrus is offline
Old 1st December 2004, 09:42   #10
raymondw
raymondw's Avatar
Eric,
Try Jacob Ofenga in Dronrijp Friesland. He migh have some.
P.S: I would not repiar it, but replace it.
Raymond
==> MY90 E34 M5 3.6 <==
==> MY85 E28 M5 M88/3 <==
The E34 M5 Alps tour. Sixth edition: 14-17 September 2007
raymondw is offline
Expensive Mistake - Part 2 Bryn E34 M5 Discussion 0 26th September 2003 10:48
Kelleners Cams & Manifold. MIB E39 M5 and E52 Z8 Discussion 40 9th August 2003 01:52
BMW 5 series one of most expensive cars to insure tfung E39 M5 and E52 Z8 Discussion 14 22nd April 2002 07:00
OT: Move to the freakin' right!!! BIMMEUP E39 M5 and E52 Z8 Discussion 20 4th October 2001 02:39
How expensive are these cars to own? Asbrink E34 M5 Discussion 4 11th April 2000 21:07
Page generated in 0.18427 seconds with 11 queries
