Old 21st July 2004, 19:49   #1
sdc77
sdc77's Avatar
Garage: Macau Blue 92 M5 3.6
Main beam replacement bulbs
I need to replace both main beam bulbs..
Having gained access to both units and disconnected the white connector.. I would have imagined it would be a simple matter of just twisting the plastic housings and removing them.. they have arrows and 'loosen' etc on them
I cant budge the plastic housings on either side..
Am I doing something wrong here.. have i missed something? I have tried really hard and I now reckon that I'm more likely to break them than remove them.
Any advice here?
1992 3.6 ///M5 - Macau Blue
sdc77 is offline
Old 21st July 2004, 19:58   #2
AndyE
Garage: Derv Burner
Send a message via MSN to AndyE
Re: Main beam replacement bulbs
It IS a simple matter of twisting the plastic knurled fitting on the back of the lamp housing.
BUT, removing one of mine was really hard a couple of weeks ago. I ended up with water-pump pliers (and a cloth to protect the lamp fitting). I heated it up with a heat-gun first to soften the plastic a little, in an attempt to make it less brittle.
It was REALLY tight, glued in place by 8 years of corrosion to the lamp housing. Good luck, keep twisting until it breaks free. If you break it (the plastic is quite weak), a new one is £13 from a dealer.
AndyE is offline
Warning for those who have bought Stg II bulbs lately TriflowM5+M3 E39 M5 and E52 Z8 Discussion 2 5th April 2003 21:30
100W H7 bulbs for high beam ok? DavidS E39 M5 and E52 Z8 Discussion 2 9th July 2002 20:06
Bright Lights. Advice on non-HID bulbs. IvanDias E34 M5 Discussion 2 25th January 2002 04:16
HID 9006 foglight bulbs for M5 atomic80 E39 M5 and E52 Z8 Discussion 4 1st June 2001 16:29
Facelift 2001 M5 ?!? BrianC E39 M5 and E52 Z8 Discussion 34 22nd September 2000 01:54
Page generated in 0.08601 seconds with 11 queries
