Old 20th July 2004, 17:13   #1
AndyE
Garage: Derv Burner
Send a message via MSN to AndyE
Heated Door Mirrors
Trying to work out why my wing mirror lenses are always dirty, I noticed they're always hot with the ignition on. Really hot to the touch!
Is this normal? Looking at the wiring diagram there's no switch. I would've expected them to be switched with the rear demister.
So, that's why they're always dirty. Dirty, soapy or screenwashy water dries on them in seconds.
Are yours hot too?
AndyE is offline
Old 20th July 2004, 17:22   #2
Mmm-Five
Re: Heated Door Mirrors
As far as I can tell they are always on - you could always replace them with the much cheaper non-heated version!
2006 e86 Z4MC (überkart)
http://mmm-five.net/
Mmm-Five is offline
Old 20th July 2004, 18:36   #3
plisken
plisken's Avatar
Garage: 95 BMW M5 green, 3.8 6spd
Yup, same here, and my 94 525 was the same...
95 E34 3.8 M5 6spd
87 Capri280 Turbo Technics, +290bhp@17psi [Not Currently For Sale]
83 Capri 2.8injection RIP
93 Mitsubishi Pajero
plisken is offline
Old 20th July 2004, 23:47   #4
AndyE
Garage: Derv Burner
Fair enough. I didn't think it was a problem after looking at the wiring diagram, but even Vauxhall can wire them to be switched by the rear demister....!
AndyE is offline
Old 21st July 2004, 00:07   #5
plisken
plisken's Avatar
Would this be a wiring diagram for the E34 or indeed one for the M5?
If it is the latter, then where did you source such a thing?
95 E34 3.8 M5 6spd
plisken is offline
Old 21st July 2004, 00:32   #6
AndyE
Garage: Derv Burner
It's for the E34. A 15Mb PDF. There are one or two inaccuracies, because the document covers the 535i.
I also have a WD for the '93 M5, but that's even less accurate, so I stick with the '95 535 one.
AndyE is offline
Old 21st July 2004, 00:33   #7
AndyE
Garage: Derv Burner
Sorry, I forgot to add - this (and PDFs for all other BMWs) was on the "ETM" CD - available from the same source as you got your ETK and TIS!
AndyE is offline
Old 21st July 2004, 00:43   #8
plisken
plisken's Avatar
All I got is the Haynes book, obviously not covering the M and the Bently book, which again does not cover the M.
What I'm really looking for, is how the deadlocking works, which is different from my 94 525, on that car the locking had two stages, one for normally locking the door, and the second stage was deadlocking and the window/sunroof closure feature. On my M5 and I'm sure many of yours will be the same, it has only one locking position and that position deadlocks the doors.
Hence I'd like to see how this is wired and how it differs from the other E34 models.
My alarm as such dos not deadlock the doors when armed, which is annoying me
Not wanting to go back to the installer, you see...
95 E34 3.8 M5 6spd
plisken is offline
Old 21st July 2004, 00:59   #9
AndyE
Garage: Derv Burner
I've uploaded the one I found to be most accurate to my LE:
E34 1995 Wiring Diagram
Please right-click, Save Target As... so you don't whack my server.
AndyE is offline
Old 21st July 2004, 01:06   #10
plisken
plisken's Avatar
Got it mate
Will have a look through tonight and see if anything jumps out at me.
Really I just need to find out where to connect the alarm's locking signal wire to, as it is obviously just locking the doors, but not deadlocking them. Would not have though it would be too difficult, might be best to pull the door card off and have a look
95 E34 3.8 M5 6spd
plisken is offline
Heated mirrors fuse? plisken E34 M5 Discussion 3 9th November 2003 21:37
Heated steering wheel ? lasseoe E39 M5 and E52 Z8 Discussion 10 24th April 2003 13:58
heated seats dont work??????? help!!! randy E39 M5 and E52 Z8 Discussion 9 9th March 2001 21:25
Heated Steering Wheel ? stanm E39 M5 and E52 Z8 Discussion 5 2nd February 2001 20:37
Button next to the heated seats? Chuck E39 M5 and E52 Z8 Discussion 4 18th May 2000 10:10
Page generated in 0.17458 seconds with 11 queries
