"Uppgrading" the clutch to 3,6 item on a 3,8 car....
Hello!
Earlier I asked if this conversion was possible and or feasible. Now it\s time to do the job. I`we checked on the ETK what parts differ; Clutch,pressure plate and flywheel and some hex nuts seem to be the parts needed.
BUT just to be sure, you people who have done the conversion, Please confirm the parts needed so that my car won\t be at the garage all summer waiting parts.
DUrability/disadvantages?
Sakke
Re: "Uppgrading" the clutch to 3,6 item on a 3,8 car....
Originally Posted by DrSakke
Hello!
Sakke
Dr.Sakke@ a 3.6 clutch into a 3.8 car ??? why that ? do u like the resistance
and wish to exercise your left foot/leg ???
the opposite is normally done, i.e. 'upgrade' a 3.6 car with the 3.8 clutch
unless it is the 'flywheel' from the 3.6 Li M5 that u intend to use
Karl / Global E34 M5touring Registry
Hi Karl!
If you read my post you`ll see that the flywheel is mentioned, Obviously it is the lighter flywheel that I`m after, the 3.6 clutch isn`t compatible with the 3,8 dual-mass flywheel. I was a little careless with my headline for the thread.
I know that there is a few people on the board who has made this job and have experience with the conversion, I`m especially interested in the adverse effect of this change in the clutch/flywheel. Does it increase load on other components and affect durability? More vibrations?
This conversion is supposed to do wonders for the throttle responce and performance of the car, the 3,6 flywheel is 12lbs compared to 29lbs for the 3,8 dual mass unit.
A matter of interest is also the exact parts needed as I have to order the parts in advance and have quite tight schedule so I can`t afford having the car at garage waiting parts....
By the way, I thought the heavines of the clutch Is mainly due to differences in the hydraylics that move the clutch, not the clutch/pressure plate in it self?
Sakke
Great pics! Thanks!
I would be thankful if you could list the new parts needed.
Is it just flywheel, clutch and pressureplate and the hex nuts, or do I need to order anything else. Just a bolt-on job or?
Negative experiences?
Sakke
Great pics! Thanks!
