In a fit of efficiency, I decided to measure my valve clearances this morning - for no other reason than I assume they're wrong!!
And, they are. Mixed over and under tolerance, here's the table.
Measuring the clearances is an easy but time consuming job - about an hour and a half from opening the bonnet to closing it again.
Cyl # ----- Intake ------ Exhaust --
---------- a ---- b ---- a ----- b --
- 1 ----- 0.21 - 0.22 - 0.28 - 0.29 -
- 2 ----- 0.25 - 0.28 - 0.31 - 0.33 -
- 3 ----- 0.22 - 0.28 - 0.31 - 0.34 -
- 4 ----- 0.25 - 0.22 - 0.33 - 0.33 -
- 5 ----- 0.25 - 0.26 - 0.32 - 0.36 -
- 6 ----- 0.28 - 0.28 - 0.36 - 0.38 -
This means that the valve lifters are outside the range of recommended tolerance as follows (red meaning overshimmed)
Cyl # ----- Intake ------ Exhaust ---
- 1 -----
0.07 -
0.06 - 0.00 - 0.01 -
- 2 -----
0.03 - 0.00 - 0.03 - 0.05 -
- 3 -----
0.06 - 0.00 - 0.03 - 0.06 -
- 4 -----
0.03 -
0.06 - 0.05 - 0.05 -
- 5 -----
0.03 -
0.02 - 0.04 - 0.08 -
- 6 ----- 0.00 - 0.00 - 0.08 - 0.10 -
So, at some point I need to either get hold of enough shims to do the job, or book it in for adjustment...
