Old 5th July 2004, 01:42   #1
johzev
Garage: 95 M5 Oxford Green Metallic
OBC set time
Anyone know how to change the time on the OBC from AM to PM? I know this is a very stupid question but I've read the manual and still can't figure it out.
Thanks, John Z.
johzev is offline
Old 5th July 2004, 01:53   #2
AndyE
Garage: Derv Burner
Send a message via MSN to AndyE
Re: OBC set time
If I remember correctly, you display the clock then press the button to the left of the display (possibly labelled oF/C). You can use this button to choose the format of celsius/fahrenheit, miles/km, mpg/L:100km and other stuff depending on the function.
AndyE is offline
Old 5th July 2004, 02:01   #3
johzev
Re: OBC set time
Andy:
Thanks for the reply. When I do as you say my display changes from AM to UHR. Not sure what UHR is all about? My car is German euro. However, I've been able to get all the other readouts in English.
Any other thoughts?
John Z.
johzev is offline
Old 5th July 2004, 09:41   #4
Gop-Dogg
Gop-Dogg's Avatar
Garage: Granite Silver `93 Euro M5
Re: OBC set time
Originally Posted by johzev
Andy:
Any other thoughts?
John Z.
UHR = military time. The time scale is 0:00 - 23:59. Set the clock to the correct time in UHR mode and then switch to AM mode.
`93 Euro M5 (3.8L)
`06 M3 CS
Gop-Dogg is offline
Old 5th July 2004, 13:09   #5
AndyE
Garage: Derv Burner
Re: OBC set time
Is the language of the OBC actually set in english? Uhr is german for 'Hour': Sounds like your OBC language might be wrong.
My obc displays 11:05 HOUR for the time, but I have the time in 24 hour mode. Perhaps you just have the time adjusted 12h too low? if you increase the hours figure, does it change to PM automatically?
If you access the OBC test codes, you can check that the language (should be LA:US for you) is set correctly.
See this document for help.
http://bmwe34m5.com/faqs/?theme=1&le...nt_id_select=3
AndyE is offline
Old 6th July 2004, 23:57   #6
johzev
Re: OBC set time
AndyE & Gop-Dogg:
You were exactly correct. I just had to adjust the time on the 24 hour clock and then set it back. Now the AM/PM is correct.
Yes, I still have some functions that are in German. The fault codes read in German. I kind of like it that way. For the most part everything is converted to US and is working properly.
Thanks a bunch for your technical expertise! John Z.
johzev is offline
My visit to the Old Timer Grand Prix on the 10th of August raymondw Regional Forums and Events and group meetings for M5, M6 and Alpina owners 2 26th August 2003 01:05
My visit to the Old Timer Grand Prix on the 10th of August raymondw Most Memorable Threads' 2 26th August 2003 01:05
Question for Math guru's....time and speed Apples E39 M5 and E52 Z8 Discussion 1 4th June 2003 18:08
Tools in trunk - Did you receive a full set? Muditha E39 M5 and E52 Z8 Discussion 6 24th June 2000 02:56
OBC: Bug or feature? greg E39 M5 and E52 Z8 Discussion 7 22nd April 2000 17:17
Page generated in 0.12280 seconds with 11 queries
