Re: High-mileage E34 M5
As with any high mileage car you would have to check the suspension, steering, clutch. not sure when the timing chains would have to be replaced?
I would get it compression tested as well if I were considering purchasing it, might give you some idea of cylinder bore wear, difficult to tell from a test drive to know if its usung oil.
But assuming it has been well looked after, its a big engine and high mileage in itself is not so bad, depends if there are other examples also around with less miles etc
But money you save on knocking the seller down for high miles you could end up paying to fix faults.
HTH
