Old 28th June 2004, 15:56   #1
Hocuspocus
Garage: M5 - Avus blue
Wandering steering/good mechanic
Dear group – not sure what other members think but I find that good mechanics are quite few and far between, so I thought I’d share my findings on one that I can strongly recommend. I’ve already posted about this on the yahoo groups page, so apologies for the repetition for anyone who subscribes to that board.fficeffice" />
I've recently bought a '94 avus blue – a truly great car, but I had some difficulties with the steering, which I couldn’t quite believe, given that I’d previously owned a ’91 for 3-4 years and spent a small fortune trying (and failing) to irradiate the slack. I had even test driven the car under every circumstance I could imagine – but it was only on the journey home that I found it …. grrr.
But the symptoms were a little different this time. As well as the slack, the car had an unnerving habit of swerving as I crossed the camber whilst braking, was far too twitchy, impossible to hold a straight line and there was uneven and excessive tyre wear.
The swerving was due to a split bush on the near side control arm, the twitchiness, tyre wear and straight lining due to significant toe out and the slack simply due to an incorrectly adjusted pre-tensioner. How the car passed the pre-sale check I'll never know!
The good news is that now all these problems have been sorted by a guy named Keith Ormiston based in Berrylands, Surrey who I can strongly recommend. He was pretty reasonable too.
Cheers.
Alastair
’94 Avus Blue
(straight as a laser!)
Hocuspocus is offline
Old 28th June 2004, 16:34   #2
Howie.San
Garage: 92 3.8 M5 Daytona Violet
Re: Wandering steering/good mechanic
I too use Keith Ormiston for looking after my 1992 3.8 M5 and I am very happy with the quality and the cost of the work he does.
He used to be the workshop manager for Coopers Thames Ditton, one of the biggest dealers in South East England, before he left to start out on his own. So you get arguably a main dealer level of expertise for half the labour rate. Indeed, I believe that Coopers subcontract some of their work to him (although whether they reduce the labour rates they charge the owner I'm not sure )
He can be contacted on 0208 390 1116 or keith@ormistonbmw.com (although he is on a well deserved holiday for the next 2-3 weeks)
Alaistair, I think you should let the M5 world know which well known dealer sold your car to you in such a state?
Howie
Howie.San is offline
Old 29th June 2004, 03:33   #3
Eric Lee
Eric Lee's Avatar
Garage: 91 M5 (e34) BLACK
I've got a wandering 91 US M5 too. I just bought it and I've wondered myself how I didn't notice it before. I've never owned a car with tires this wide, so I thought at first that this was just a little tramlining and that it was to be expected. but driving close to the "New Jersey Barriers" (our version of Armco) has been a nerve-wracking experience.
I've seen that several others have had this problem and the first cause seemed to be looseness in the steering box. my local shop thinks this is rare, but they don't work on M5s much and I know the box is unique to this model. I checked the spline nut under the dash and it was tight.
my shop has said from the start that the first thing to do is get an alignment. I didn't think that was it since the car tracks pretty straight, but pulls to the left with each bump. now I'm inclined to agree with them. They checked for excess play with the car on the rack and found none. the bushings all look good.
I think outward toe might be the problem. the shoulders of the front tires are bald, but I figured they'd been rotated from the rear. now I think the outward toe has caused them to wear out on the front.
My plan was to replace bushings or tighten the box before buying tires since it'll need an alignment and I didn't want to do it twice. the rears are pretty shot as well, so I ordered a set of Pilot Sports that are going on the car on Friday. I'll get an alignment afterwards and report back! Here's hoping it's not anything more expensive!
Eric Lee
Eric Lee is offline
Old 29th June 2004, 11:43   #4
Hocuspocus
Eric - you really need someone who knows the M5 e34 set up. alternatively, there are some very good posts on this board and the yahoo board which together comprise a very comprehensive check list. Email me off line if you want the one I compiled.
Cheers.
Alastair
Eric Lee
Old 29th June 2004, 11:55   #5
Hocuspocus
Name and shame! I may just do that, but I am discussing with "them" how they might make good ... so watch this space!
Hocus
Howie
Old 18th August 2004, 22:36   #6
squiresM5
Garage: E34 M5
Ive got the exact problem on my 91 M5...However, I bought the car with the stock wheels and dunlop super sport tires and the car ran perfectly straight. I then purchased aftermarket wheels/falkon ZR rated tires from "Wheel Exhange" with the exact size specs as the originals. I had the new wheels/tires mounted and balanced on the car, and the second I drove it I noticed a major wander in the steering and the car will not hold a straight line. It is being aligned and the box is being tightened this week, however, I know this is not the problem. My next try is trying the old tires on the new wheels. Does your M5 have the stock or aftermarket wheels??
I have had three shops drive the car, and they all say the tire tread or alignment is off, but the car ran great with the stock set up. Also, the new tires have 3k miles on them, and they are wearing perfectly.
VERY FRUSTRATING!!!
Please let me know how your new tires work out.
Darin
Eric Lee
squiresM5 is offline
Old 19th August 2004, 02:51   #7
UltFamCar
UltFamCar's Avatar
Garage: 1991 Dinan E34 M5
Send a message via AIM to UltFamCar Send a message via Yahoo to UltFamCar
Hi Alastair,
For the benefit of all, can you post your checklist here? If not, I would appreciate your list as I too am a victim of the Wandering Steering problem! BTW, the dealer has already adjusted my steering box and that seemed to help only a little bit. But I've got bigger items to resolve to totally correct this problem, including worn idler arm, torn front sway bar links, etc....
My email is DinanE34M5@gmail.com
Thanks,
Charles
Cheers.
Alastair
E34 1991 Dinan M5 | Jet Black/Black | '93 Clutch & Flywheel | Dinan Chip | Dinan Stage I BBK (F/R Centric Rotors, Front Hawk HPS Pads, Rear Axxis Ultimate Pads)| F/R StopTech SS Brake Lines | Dinan Stage III Suspension | Dinan Floor Mats | OEM F/R Clears | UUC EVO3 SSK & DSSR | UUC Black Transmission Mounts | BMWCCA #275170
E39 1999 528i Touring | Touring Sport Package | Auto | Jet Black | Black Montana Leather | Xenons | Moon | Heated Seats | OEM Alarm | OEM M5 Front Bumper Kit | OEM M5 Rear Sway Bar | Brembo OE Replacement Rotors | StopTech SS Brake Lines | Axxis Ultimate Brake Pads | ATE TYP 200 Brake Fluid | (Wifey's Car)
E46 - 1999 323i | Sport | Manual | Jet Black | Tan | Myrtle Wood | Moon | Rear-folding seats | Michelin Pilot Sports | OEM Clears | UUC BB Clutch Stop | M3 Lip Spoiler | Dinan Stage I [SOLD]
Words of Wisdom:
"Friends don't let friends drive automatics!"
"If it ain't RWD, it's WWD (Wrong Wheel Drive)!"
UltFamCar is offline
Old 27th August 2004, 01:50   #8
Eric Lee
Eric Lee's Avatar
Darin,
sorry, but this isn't going to be much consolation. I have 17" throwing stars, and I put new Pilot Sports (not PS2s) on and that seemed to take care of the problem. I did have the car aligned (just front end, none of the local tire shops could find specs for the rear on that car....whatever, saved me $40), but the tech who did the work said the alignment was pretty good beforehand. I didn't drive the car at all between the tires and alignment jobs, so I can't say for sure.
The yokos that were on front when I got the car two months ago were worn on both inside and outside shoulders. maybe they came off the back during a rotation and were already worn. I can't say for sure....
Eric
Eric Lee is offline
Old 27th August 2004, 15:43   #9
Phlem5
Garage: 92 3.8, 5sp, Avus Blue(SOLD) & 95 LE 25/50
try this link for alingment spec's http://bmwe34m5.com/faqs/?theme=1&le...nt_id_select=3
I don't know how to shorten the link so hopefully it will get you where you need to go.
cheers,
Phil.
Phlem5 is offline
Old 1st September 2004, 01:57   #10
prairieman
Garage: Black E34 M5
hey Alastair,
my newly acquired M5 has similar "wandering" steering. Your original post stated: "slack simply due to an improperly adjusted pre-tensioner"
if I may be so bold.... what the heck is a "pre-tensioner"
I would like to adjust mine.
thanks
Brad
1979 635CSi
1981 745i
1991 M5
1992 735i
prairieman is online now
NYC mechanic needed. kipper E39 M5 and E52 Z8 Discussion 3 13th December 2003 08:49
Overheating idle, superb quick job by mechanic!! IvanDias E34 M5 Discussion 1 28th June 2003 06:49
Need realiable mechanic in Marin County Bmxbikergtss Off Topic Forum 0 21st June 2003 19:30
NEED HELP Opinions for becoming a BMW mechanic? 92Typhoon Off Topic Forum 4 22nd April 2002 15:41
My mechanic is moving to BMW/NA in NJ! :(( AndyMenard E39 M5 and E52 Z8 Discussion 5 15th October 2001 02:34
Page generated in 0.24968 seconds with 11 queries
