Old 28th June 2004, 12:40   #1
Nuno Miguel
Garage: Bmw e34 3.6 M5 Red
Correct oil level on the engine???
I have reported some strange events, it hapen to me some times, the OBC said "engine oil low" 2 days a go it did it again, i let the engine cool down, and the oil level on the oilstick was almoust max. the warning was showed when i turned off the engine (right after).
After i had a close look at the oilstick, i saw that there are to 4 marks!!!
The 2 marks that are easyer to see are 2 "cuts" on the plastic stick, seperated by +/- 2 centimeters, but there are other 2 marks, (it looks like a ring on the oil stick, you can see that the plastic is a bit salient on that zone)
one is just bellow the 1º cut on the stick, and the other is aprox 5 centimeters up (+/- 2.5 centimeters higher then the other cut)
A bit like this: «----*-/----/------*--------------------------O
The / is the two cuts
The * is the "rings"
This got me confused , what should guide us?
Nuno Miguel is offline
Old 28th June 2004, 14:34   #2
AndyE
Garage: Derv Burner
Send a message via MSN to AndyE
Re: Correct oil level on the engine???
To aid Nuno's description, here's a photo of my dipstick.
In my understanding, the two cuts represent min. and max. oil level, separated by approximately 1 litre of fluid level.
As far as I'm aware, the other rings on the dipstick are plastic mouldings and don't represent anything. The numbers are the BMW PN, excluding the 11 (Engine) prefix.
Nuno: Perhaps there's something amiss with your car's oil level sensor? I believe its quite an expensive part to replace though...
AndyE is offline
Old 28th June 2004, 15:11   #3
kevinpayneuk
kevinpayneuk's Avatar
Garage: E34 M5 Cosmos Black
Agreed...the two cuts are upper and lower levels
Kevin
'89 E30 M3 Cecotto - Macao Blue
'95 E34 M5 3.8 6spd, MParallels etc - Cosmos Black
'98 E39 528i Touring Auto - Calypso Red
'04 E46 330Ci Convertible - Titan Silver
kevinpayneuk is offline
Old 28th June 2004, 19:21   #4
Nuno Miguel
Is it normal to the oil level sensor have problems?
Old 28th June 2004, 19:56   #5
RandyZ
Garage: 1991 M5 Black
I have the same warning on my 91 M5. If I park on a incline and the oil level is below the half way mark I get the warning. Could be my sensor also acting up. Filling up to the top mark and most times goes away.
RandyZ is offline
Old 29th June 2004, 01:19   #6
Kurt Ramsden
Garage: e34 3.8 M5
I'm having a very similar problem on mine Nuno - OBC keeps saying 'low oil' and it's almost at max on the dipstick.
I don't know whether this is significant, but mine started doing this after I drove over a speed-bump faster than intended (I didn't even see the b**dy thing). I actually thought I'd holed the sump, but it isn't even marked in any way. Have you had a similar experience recently, because I suspect that the shock of the bump has broken or confused the sensor in some way?
There again I could be connecting two unconnected events in some kind of bizarre 'choas theory' way which has no bearing on reality.....
Kurt Ramsden is offline
Old 29th June 2004, 02:24   #7
M5 powered
Garage: M5 limited edition (02/50) Rosso Red
Don't worry, the oil sensors seem to wear out quite quickly. My car has had two of the sods. The last one was when I bought the car - low oil light even after its inspection two had been completed. The garage replaced the sensor and I've never had a problem since (touch wood).
BTW, its my understanding you shouldn't get a low oil light even when the car is on a hill etc.
Best
Jonathan
1995 M5 Limited Edition (02/50)Rosso Red
Pilot Sport 2 Rubber
Valentine One With Conceal
Twin Head LRC100 IR Jammer System
Origin Blue B2 GPS
M5 powered is offline
Old 29th June 2004, 18:57   #8
Nuno Miguel
mmmmm, it seems so... any way, the best is check the oilstick everey full tank of fuel (the manual says it!!! the M´s shure like fresh oil!)
Probaly it has someting to do with speedbumps, cause i have 2 giant speedbumps on my way home.
oil consumption, the solution ? Van Volsem E39 M5 and E52 Z8 Discussion 0 19th July 2003 22:03
Checking oil, back to basics? kwalls E39 M5 and E52 Z8 Discussion 25 29th April 2003 02:04
oil level... jack880 E34 M5 Discussion 1 24th March 2003 18:50
What level should my oil be at after 5 days....... Apples E39 M5 and E52 Z8 Discussion 5 24th June 2002 17:24
engine oil shortage michel E39 M5 and E52 Z8 Discussion 4 1st April 2000 16:05
Page generated in 0.13618 seconds with 11 queries
