I've asked this question before "I think"...
the Check Engine lamp on the dash on my car does not illuminate.
1 Should it illuminate for a few seconds when the ingition is on, like the ABS and Air Bag lamps?
2 I've tried removing various sensor plugs under the bonnet, to try and get it to come on but it does not, is there any way to check it is functioning?
3 I've tried the method to read the codes, but it does not flash, should it, if there are no current faults?
My 94 525 was exactly the same, don't want to start pulling the dash apart to replace a bulb that may be ok!
