Old 25th June 2004, 15:02   #1
Zippy
Zippy's Avatar
Garage: BMW 335i M Sport
Rollers !!
Does anyone have any thoughts and/or knowledge on replacing the front and rear Anti roll bars on the M5 ....??
I would be interested in hearing about different setups advanatges disadvantages etc , and how you have found it compared to the standard setup
Many Thanks
Zip
Zippy is offline
Old 26th June 2004, 01:15   #2
M5touring reg
M5touring reg's Avatar
Garage: 95B M5touring Avusblau,met.
Re: Rollers !!
Many Thanks
one simple and straight forward 'uppgrade' is to use the rear anti roll bar
from the M5touring
(PS: did u ever get the goodies from the -mobile tradition- ?)
Karl / Global E34 M5touring Registry
M5touring reg is offline
Old 26th June 2004, 06:47   #3
Zippy
Zippy's Avatar
Re: Rollers !!
Karl.................
Nice to hear from you, hope you are well ...
Will the rear upgrade from a Touring be sufficient without upgrading the front ?? How does your Touring handle compared with a saloon??
I have spoke with Herr Jacobsen and it appears the Goodies have gone missing in the post
They are arranging a new Certificate ..but sadly I have missed out on the brochure...
Good to hear from you...
ZIP M5 LE 33/50
Zip
Zippy is offline
Old 26th June 2004, 20:32   #4
AirKuhl
Garage: Arena Red 993 C4S
Re: Rollers !!
What specifically about your chassis tuning are you trying to change?
AirKuhl is offline
Old 26th June 2004, 21:06   #5
dronfieldm
Garage: 1995 BMW M5 3.8 6 Speed - Avus Blue
Re: Rollers !!
I can't remember where I saw it, but feel sure that the 1995 cars with the Nurburgring suspension had the 1mm thicker rear anti-roll bar as standard........same as the touring.........
...must try and find where I read it..........and add it to this post.
Anyone else think this ? Or just me ?? !!
Found one extract here....
http://member.rivernet.com.au/btaylo...tiveSuspe.html
"but sadly none of the
performance goodies - the awesome 3.8L engine, the EDCIII+ adaptive
suspension, or even the Nurburgring package of larger rear wheels and tires
and enlarged rear sway bar. But, can the EDCIII+ be adapted to the US spec
car?
Here's where I read that the 1995 car has a 1mm thicker rear sway bar (20mm), but no mention of what the touring has....is that bigger still ?
http://www.bmwcarclubgb.co.uk/sectio...on%5B2%5D.htm#
Mark
1995 3.8 6 speed - gone, but not forgotten.
1999 Land Rover Discovery Td5 ES
dronfieldm is offline
Old 26th June 2004, 22:10   #6
kevinpayneuk
kevinpayneuk's Avatar
Garage: E34 M5 Cosmos Black
Re: Rollers !!
IIRC mine, with the Nurburgring suspension, has a 19mm rear bar whereas the Touring is 20mm
Kevin
'89 E30 M3 Cecotto - Macao Blue
'95 E34 M5 3.8 6spd, MParallels etc - Cosmos Black
'98 E39 528i Touring Auto - Calypso Red
'04 E46 330Ci Convertible - Titan Silver
kevinpayneuk is offline
Old 26th June 2004, 22:22   #7
dronfieldm
Re: Rollers !!
Here's where I read it was 20 mm.
http://www.bmwe34m5.com/registry/HTMLFiles/WZ.htm
Having just looked through the original BMW press pack for the 3.8 M5, it states that the roll bar on the Nurburgring package is 19mm, instead of 18mm.
Suppose that clears that up. You know what it's like when you can half remember something.........!!
So a 20 mm from the touring would stiffen the rear up, and cause more understeer ??
Mark
Old 27th June 2004, 03:04   #8
AirKuhl
Re: Rollers !!
Mark
No. Stiffening the rear relative to the front will decrease understeer.
--Pete
AirKuhl is offline
Old 27th June 2004, 04:37   #9
Zippy
Zippy's Avatar
Re: Rollers !!
What I am trying to achieve is a little more stability when cornering at speed
ZIP M5 LE 33/50
Zip
Zippy is offline
Old 27th June 2004, 09:04   #10
AirKuhl
Re: Rollers !!
What I am trying to achieve is a little more stability when cornering at speed.
OK, does that mean that you are feeling too much body roll or wallowing in corners? If so, I would recommend stiffer springs and perhaps shocks with better damping circuits. Just getting a stiffer rear anti-roll bar without any other changes will only slightly increase body roll resistance while also increasing the car's propensity to oversteer.
If you mean that the rear breaks loose too easily when applying power on corner exits (fun but slow), you want to firm up the front, not the rear.
If you mean the front plows too much, the stiffer rear bar will help a bit, but learning to enter the corner a bit slower will help a lot and also allow you to exit much quicker and in a more neutral attitude. Plus, it's free.
Good luck,
--Pete
AirKuhl is offline
Car on the rollers today plisken E34 M5 Discussion 1 23rd May 2004 02:14
Dyno Strike 2. MIB E39 M5 and E52 Z8 Discussion 15 9th July 2003 16:40
B8 on the rollers Frosty ALPINABoard.com | BMW Alpina Discussion 6 7th December 2002 19:20
Page generated in 0.15175 seconds with 11 queries
