Old 27th May 2004, 21:56   #1
plisken
plisken's Avatar
Garage: 95 BMW M5 green, 3.8 6spd
Oil Temp' on the increase...
I notice my oil temp' almost aproach the middle of the scale today, never really seen it this high before, always sits below, the mark to the left of centre, which I'm lead to believe is normal.
But...
today, under normal driving conditions, albeit through traffic, it started to creep up near the centre, although I must point out that the collant temp' stayed bang on the centre, as it normally does.
A result of the hotter weather (26 today) or is my engine about to blow?
I suppose it would also help get ideas of Skylines and Lancer Evo's out of my head...
Only other difference is that I have been using Optimax (98) for the past couple of days
95 E34 3.8 M5 6spd
87 Capri280 Turbo Technics, +290bhp@17psi [Not Currently For Sale]
83 Capri 2.8injection RIP
93 Mitsubishi Pajero
plisken is offline
Old 28th May 2004, 00:15   #2
ilundber
ilundber's Avatar
Garage: 1991 M5 Lagunengrunmetallic and 2001 M5 Le Mans Blue
Re: Oil Temp' on the increase...
Built on experience, I have learnt the the oil thermostat opens when the needle is just to the right og the centre position. If memory serves me correctly, it opens wide at 105 degrees centigrades.
ilundber is offline
Old 28th May 2004, 00:44   #3
M5touring reg
M5touring reg's Avatar
Garage: 95B M5touring Avusblau,met.
don't worry, appears normal in -stop and go-traffic- in 26 degrees C outdoor
temperature, once you get a clear road and the oil thermostat kicks in -
as -ilundberg- rightly says at about 105 degrees - oil-temp will drop rapidly
with water temp remaining constant -
Karl / Global E34 M5touring Registry
M5touring reg is offline
Old 28th May 2004, 00:45   #4
plisken
plisken's Avatar
I'm almost 100% sure that mine has never went above the half way point, was pretty close to it today though, hopefully nothing to worry about, and simply a result of the hot weather.
plisken is offline
Old 28th May 2004, 00:51   #5
M5touring reg
working temp shud be 90 degrees, just left of center -
working range is abt 80-120 degrees i.e. half way point is no problem at all,
a constant 80 degrees is too cool, ok for a short while and during warm up -
Old 28th May 2004, 10:51   #6
dronfieldm
Garage: 1995 BMW M5 3.8 6 Speed - Avus Blue
Mine goes to centre if I overtake a few lines of cars and then hold onto the revs/middle gears through a series of bends.............only goes spot on centre though......
After that, and normal driving, just left of centre. In traffic and hot, I am sure it would rise also, but last time I was in a traffic jam on the M6, I either turned the engine off or put blowers on full hot - to aid heat removal.
There seems to be nothing wrong with your oil temp........
Mark
1995 3.8 6 speed - gone, but not forgotten.
1999 Land Rover Discovery Td5 ES
dronfieldm is offline
Old 1st June 2004, 23:05   #7
orinoco
Garage: M5 LE orinoco
I had the same problem when I had my car serviced at main dealer who now all seem to use fully synthetic oil. I had them change it to semi-synthetic which would be compatible with the era of the engine design and it certainly made a difference to the running temp. Have just had it serviced again and thought that maybe I had been imagining the hot running last year - sadly not and with the same problem again I shall shortly be back to them with a couple of jugs of the semi-synthetic stuff!
I had been meaning to ask if anyone could provide a technical reason for this as the dealer seems to have none. Anybody got an answer?
orinoco is offline
Checking oil, back to basics? kwalls E39 M5 and E52 Z8 Discussion 25 29th April 2003 02:04
Increase in oil consumption Mark E39 M5 and E52 Z8 Discussion 1 27th February 2003 19:39
how to lower oil temp tfung E39 M5 and E52 Z8 Discussion 7 22nd June 2002 10:54
Oil level = oil temp? ALX E39 M5 and E52 Z8 Discussion 15 17th January 2002 02:46
Q: Is oil temp change normail after service? M5_Surge E39 M5 and E52 Z8 Discussion 12 8th February 2001 12:52
Page generated in 0.13784 seconds with 11 queries
