Just passing along some info that was discussed a while back on the
http://autos.groups.yahoo.com/group/bmwe34m5/
"The crank journel is 1mm larger on the S38B38 crank
then on the S38B36. The big end of the rod is the same
size on both engines so the actual bearing shell is
0.5mm thinner on the S38B38. This coupled with the
shorter rod length, longer stroke, higher compression
(of the S38B38)increases the bearing loads alot.
Thinner bearings are not going to hold up as well in
the long run. Detonation takes its toll faster."
Hope this helps.
Rick
