Old 16th December 2003, 19:34   #1
M5e3438
M5e3438's Avatar
Garage: E34 M5 3.8 Granit Silver
Central locking
One of the rear passenger doors stopped responding to the central locking some months ago - meaning I had to physically push or pull up the stalk to lock it. Then two weeks ago it started responding again. Today its gone back to its bad ways and wont function.
Any tips for simply sorting this out?
Cheers in advance and happy Xmas
Frank
M5e3438 is offline
Old 17th December 2003, 11:33   #2
Richard Fathers
Garage: 1995 E34 M5 Orinoco
Sticky relay perhaps?? You could try swapping the relay from the other rear door and see if that cures it
Richard
1995 M5 Limited Edition 01/50 Orinoco Green
Richard Fathers is offline
Old 17th December 2003, 13:13   #3
vadas1
vadas1's Avatar
Garage: 1994 m5 / diamond black
I had an E30 325i that started doing that. Like Richard Fathers says try the relay first but be prepared for some rewiring work. It didn't cost a fortune on the E30 but then again its not an M car and I have a very friendly garage.
ralph (vadas1)
* If it ain't broke fix it till it is *
vadas1 is offline
Old 17th December 2003, 14:19   #4
M5e3438
M5e3438's Avatar
I assume that involves taking off the door panel? Is there a fool proof way of doing it without destroying everything (havent taken one off before)
Ta
Frank
`93 3.8 M5 Limousine Silber Granit
'07 GTS250 cappucino expresso bongo
an old pond - a noise - as a frog jumps in
M5e3438 is offline
Old 17th December 2003, 14:49   #5
ECM4
ECM4's Avatar
Garage: E34 M5 3.8 6sp Kashmir Biege
I had problems with an E30's locking. I bought a new control box for about £70 (I think its in the drivers footwell or maybe in the door) but it made no difference.
Eventually I realised the rubber boot that covers the wiring connector in the drivers door hinge was loose. The connector was full of water. I dried it out and it worked fine.
Worth looking at all the door wiring connectors...........especially the drivers door because it's all worked from there.
I have a new E30 control box if you'd like to try it.
ECM4 is offline
Old 17th December 2003, 17:03   #6
M5e3438
M5e3438's Avatar
Cheers I'll check it out
Frank
M5e3438 is offline
Service in central Florida? RKS E39 M5 and E52 Z8 Discussion 1 11th July 2002 00:02
Central locking bibbya E34 M5 Discussion 4 24th January 2002 13:27
Time For Another Gripe About Central Locking alpywhite E39 M5 and E52 Z8 Discussion 17 26th November 2001 07:51
How do you program locking functions/Auxill heaters jfm E39 M5 and E52 Z8 Discussion 1 4th March 2001 17:35
Central Florida/Orlando///M meet. Mel A E39 M5 and E52 Z8 Discussion 6 4th March 2001 02:54
Page generated in 0.11273 seconds with 11 queries
