Old 16th September 2003, 20:26   #1
ian hall
Garage: 95 M5 Avus Blue
Front discs
I just changed the front pads on my 94 3.8. The discs say min thickness 30.4mm mine are 28mm!!! How much are a pair going to cost? I assume they will be genuine only, can,t imagine anyone would make pattern ones for a car this rare.
Ian Hall
ian hall is offline
Old 16th September 2003, 23:47   #2
M5 powered
Garage: M5 limited edition (02/50) Rosso Red
Hi Ian, Don't see your'e car floating round Warwick, You moved!
As for the front discs yes they are BMW only I'm afraid and around the £130-150 mark each from memory.
Look on the bright side though, they are probably one of the few brake discs in the world still hand made!
The rears are about £60-£70 each...again from memory.
regards
Jonathan (M5 Powered)
1995 M5 Limited Edition (02/50)Rosso Red
Pilot Sport 2 Rubber
Valentine One With Conceal
Twin Head LRC100 IR Jammer System
Origin Blue B2 GPS
M5 powered is offline
Old 17th September 2003, 00:33   #3
Bryn
Garage: BMW M5, Black, 1993, 3.8
Hi there,
I guess from Jonathan's post that you have a floating disc car, but just in case its an earlier 3.8, the non-floating discs are £64 each p/n B34.11.2.226.385.
Cheers,
Bryn.
Bryn is offline
Old 17th September 2003, 01:24   #4
Artur Costa
Garage: E34 M5 3.8L
My dad installed new front disks on our 92 3.8L and the box said "750 front disks" this is strange but I went to see a 750 (the old ones) and the disks are really the same...
Never heard of that "hand made disks" you say....
Artur Costa
"as soon as the road turns - look in the rear view mirror, and there you will se the AMG´s"
1992 E34 M5
Artur Costa is offline
Old 17th September 2003, 02:37   #5
Brian M5
Brian M5's Avatar
Garage: 1995 E34 M5 LE Rosso Red
Looks like M5 Powered's memory is right in the ball park.
I've a receipt says they are £112.50 + vat for the floaters
E34 M5 UK LE Rosso Red / Champagne.
Brian M5 is offline
Old 17th September 2003, 19:28   #6
ECM4
ECM4's Avatar
Garage: E34 M5 3.8 6sp Kashmir Biege
I've some of those reciepts and I'm sure they say £120ish.....
Remember they're handed!.....Flutes facing backwards.......
ECM4 is offline
Old 18th September 2003, 01:50   #7
M5 powered
Arthur,
The large floating calipers had 345 mm disks manufactured for BMW. Each one is hand made and signed by the builder. My last set were made by Kirk and the other unreadable.
Anyway, from looking at the construction their job entails welding the spindles to the outercasing and then testing the run out prior to shipment.
Taa Daaa!
regards
M5 Powered
Origin Blue B2 GPS
Nowack Tuning Report, The Truth (Long Version) CharlesW E39 M5 and E52 Z8 Discussion 61 7th January 2009 11:06
First pics of the E60 M5 front brake discs - sort of :) Tom_K E60 M5 and E61 M5 Touring Discussion 8 2nd October 2003 00:06
Nowack Tuning Report, The Truth (Long Version) CharlesW Most Memorable Threads' 44 30th November 2002 05:49
1995 M5 front brake discs john elmes E34 M5 Discussion 4 3rd July 2002 15:54
Page generated in 0.16197 seconds with 11 queries
