Well, when I changed the clutch I also changed the pressure plate, pilot bearing t/o bearing, tranny input shaft seal, rear crank seal, gear selector rod seal, flex disc, center bearing and all the exhaust gaskets. It all ( except the drive line stuff) comes in a complete kit from bavauto.com. The problem I noticed is that the oil pan gasket is rock hard. When I was changing the rear crank seal I noticed the oil pan gasket was very hard and brittle, so I sealed up the rear seal and placed the order for the oil pan gasket. I have noticed a slight leak now from that spot. I'm hoping I can get the oil pan gasket on there before the clutch disc gets saturated with oil. Man, taking that tranny out is not fun.
Anyway, I'll keep you all up to speed.
