hi there
The windscren washer jets are cliped in to bonnet but to remove them you have remove sound deadning pad under top par of the bonnet to remove the washer pipe and unclip the electric plugs if the washer jets are heated.
it quite posible that scale has built inside the washer jets and blocked them, you could try removing them and soaking them in descaler liquid for a couple of hours, if you cant find descaler, you can use vinegar that works prety well too.
the use compressed air to clear out any debri inside them.
regards
joe rubido
